ABS Brake Problem?
Old Mar 11, 2003 | 09:18 AM
AZ350Z's Avatar
AZ350Z
Default ABS Brake Problem?
I heard over the weekend that there was a problem with the ABS system if you run all four tires the same size. Anyone have any info on this? I obviously have the same size all the way around.
Old Mar 11, 2003 | 10:12 AM
jackwhale's Avatar
jackwhale
I don't have the answer but I do remember reading some threads which talk about this. As I recall there was concern that the ABS measured wheel revolution and based its response on the the different circumference front to back. Some thought that changing the ratio between front and back wheels might confuse the computer and render ABS less effective.
I couldn't easily find the thread but this is what I recall.
Uriyo_
Sep 8, 2021 08:46 AM
