How many RPMs should the engine idle at?
Old Oct 12, 2006 | 04:54 AM
Tay350z's Avatar
Tay350z
Default How many RPMs should the engine idle at?
If it's not broke?
Old Oct 12, 2006 | 04:55 AM
savvy's Avatar
savvy
mine goes at like 700 05 z
Old Oct 12, 2006 | 05:31 AM
CLMZ's Avatar
CLMZ
mine shows approximately 800 - 06
Old Oct 12, 2006 | 05:47 AM
Fletch69z's Avatar
Fletch69z
about 700
Old Oct 12, 2006 | 06:20 AM
SS728's Avatar
SS728
'06. 750 rpm.
Old Oct 12, 2006 | 07:25 AM
shushikiary's Avatar
shushikiary
depends, when it's cold out and the car just started and I have the heat set to auto, it idles at about 1200 until it gets warm, then goes down to about 700... when the AC is on full blast in the summer it's around 1000, but no ac, no heat, it's about 700 most of the time.
Old Oct 12, 2006 | 08:49 AM
highside107's Avatar
highside107
Yeah, it's about 700-800rpm or so when the engine is warm.
Old Oct 12, 2006 | 08:50 AM
Swiffer's Avatar
Swiffer
Old Oct 12, 2006 | 08:53 AM
ZBigDog's Avatar
ZBigDog
700-800 over here
Old Oct 12, 2006 | 08:58 AM
davidf's Avatar
davidf
Well since my spark plug change and throttle body was cleaned my tach sits on 1000.
Old Oct 14, 2006 | 01:35 PM
dTor's Avatar
dTor
600 on my '03 G coupe. It didn't start idling this low until after a few mods. ECM reset did not change it, either.
Old Oct 14, 2006 | 04:32 PM
GFrnk69's Avatar
GFrnk69
wow im at 400rpm's is that bad?
Old Oct 14, 2006 | 07:39 PM
genegoesfast's Avatar
genegoesfast
"How many RPMs should the engine idle at?"
ending a sentence with a preposition.....tisk tisk
750 by the way
Old Oct 14, 2006 | 10:58 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The service manual spec for the A/C off idle speed is 650rpm plus or minus 50rpm
I prefer something higher, like 850.
Old Oct 14, 2006 | 11:50 PM
redline350ZZ's Avatar
redline350ZZ
1100-1200 RAWR...I need to get that fixed...Nissan Hawaii wont adjust it for me tho...lol
1st Nissan Florida bumped it to like 900 when I had my tilton installed then Techno Square accidentally added a bump too cause they thought it would over ride my Nissan bump and I ended up with the high idle...I then thought Turbonetics reflash would knock it down a little but it didnt and Hawaii nissan wont do it for me...yikes
Old Oct 15, 2006 | 06:43 AM
Q45tech's Avatar
Q45tech
Once you set the idle at correct rpm and the dynamic IAC percentage correctly and changes after warm up should be an excellant indicator of problems beginning.
I use the IAC % duty cycle [OBD2] to tell me when to clean TB [idle drops],
You cannot rely on dash tach to tell you much at low rpms it is pretty inaccurate and hard to resolve 25-50 rpms.
Higher than necessary [for smoothness] idle just wastes gasoline.
Old Oct 15, 2006 | 06:39 PM
dovla's Avatar
dovla
Q45tech, what is IAC? My dealer wants 1 hour for cleaning TB at 30K service – and they won’t remove TB for this. So how is this done? Thanks
Old Oct 16, 2006 | 06:47 AM
Q45tech's Avatar
Q45tech
IAC = idle air control
On older engines this was a separate bypass around the TB [a screw adjustment to manually set % of air and more importantly a solenoid bypass [that pulsed in addition air/time] around the manual part so ecu could add enough extra air to get 1500 rpm [to act as a throttle dash pot on deceleraation and to increment air under AC, power steering, and alternator loads- lights,etc]. 10-15% duty cycle of just no load idling , add AC =35%, turn on lights more, turn steering more...........AT 60 mph duty cycle 70% so when you suddenly let off throttle the rpms don't fall to 650 and the engine doesn't die.............progressive drops in duty cycle as the car slows down.
Modern cars intergrate this in TB plate motor software so ecu cracks throttle to accomplish same thing.
Why you calibrate throttle pedal closed potentiometers [voltage] and then ecu adds addition voltage to TB motor.
Modern TB [with motor to control] are very very sensitive of solvents [spraying them in TB can cause expensive TB failure]............time consuming [labor expense] Q tips and cloths very very little solvents. Older cable controlled were almost indestructable.
Old Oct 16, 2006 | 10:39 AM
Bananax's Avatar
Bananax
650~700. 750~800 with AC on.
