Race Gas, NA?
Old Oct 18, 2006 | 07:59 AM
  #41
mario60185's Avatar
mario60185
Chicago Realtor
NO one said our stock car calls for race gas. Once again you failed to read the thread.
Old Oct 18, 2006 | 08:13 AM
  #42
97supratt's Avatar
97supratt
Originally Posted by jackie chan
10.3:1 is high compression and calls for race gas....now i have heard it all.
It's not? Pump some 87 and see what happens. Kaboom
So, on a stock 10.3to 1 compression car, the difference between 87 and 91 is big. So difference between 91 and 100 should be just as big.
Thanks for making me look smarter.
Old Oct 19, 2006 | 07:51 AM
  #43
chimmike's Avatar
chimmike
Originally Posted by danielwebb
I have a popcharger only and I put in about 33% 100 octane to 66% 93 today and I could tell a deffinite difference.
Old Oct 19, 2006 | 12:19 PM
  #44
davidf's Avatar
davidf
But it for the smell, it smells wonderful exiting the exhaust, yes it's expensive but it smells good. hehehe.
Old Oct 19, 2006 | 01:18 PM
  #45
97supratt's Avatar
97supratt
Yup, especially when you go into the leaded race gases.
Old Oct 19, 2006 | 02:58 PM
  #46
chimmike's Avatar
chimmike
yup. it smells great as it kills your oxygen sensors.
Old Oct 19, 2006 | 03:00 PM
  #47
DanielW's Avatar
DanielW
Originally Posted by chimmike
If 93 dynos higher than 91 why wouldn't 95 or so dyno better than 93? Or is 93 the magic octane that makes z's operate at maximum efficiency?
Old Oct 19, 2006 | 08:05 PM
  #48
mario60185's Avatar
mario60185
Chicago Realtor
um...im guessing cause 90% of the us has a max of 93 at most pumps.
Old Oct 20, 2006 | 07:32 AM
  #49
97supratt's Avatar
97supratt
Well some of us don't mind.
But I do agree, anything under 600whp should be fine with 100 octane, there shouldn't be any knock being recorded with 100. No need to go any higher into the leaded gases.
Old Oct 20, 2006 | 07:40 AM
  #50
You have never been to the dragstrip have you?
Old Oct 20, 2006 | 07:50 AM
  #51
mario60185's Avatar
mario60185
Chicago Realtor
Yes I have, but MOST of us, dont buy gas from the dragstrip, we go to local GAS STATIONS.
Old Oct 20, 2006 | 07:52 AM
  #52
chimmike's Avatar
chimmike
because the ignition timing was tuned for high octane gas. But beyond the 93 pump taht the ECU was meant for, there's nothing to be gained.
OCTANE DOES NOT MAKE HORSEPOWER, IT HAS TO BE TUNED FOR HIGHER OCTANE TO MAKE THE HIGHER HORSEPOWER!
Old Oct 20, 2006 | 07:55 AM
  #53
LOL. The question is for the OP.
Old Oct 20, 2006 | 09:46 AM
  #54
Ztampa's Avatar
Ztampa
Maybe this will help.
I asked Sharif about high octane on N/A w/ Utec in this thread, and he said they had tried it and didn't get any significant gain.
The major advantage to high octane is to prevent detonation. So, you could advance timing without knock. However, it seems that the VQ stops responding to added timing before it starts to knock. So, there wouldn't be a big difference.
Old Oct 20, 2006 | 09:58 AM
  #55
mario60185's Avatar
mario60185
Chicago Realtor
Do you know what modifications the car had? and what does significant gains mean?
Old Oct 20, 2006 | 10:43 AM
  #56
97supratt's Avatar
97supratt
I don't know what you guys are smoking, but it must be strong.
I am living proof that 100 octane helped in my Z. You can either believe or not, but it does. Especially in hot weather where these engines do "knock", and if you have race gas it wont knock therefore you have more power.
The timing you guys are talking about is base timing. Base timing doesn't prove $hit. The ecu will advance timing until it detects knock, then it will retard until its gone, then advance again. That is the purpose of ignition timing.
Race gas will advance timing to the limit the ecu is willing to go without knock and it will keep it there all across the rpm range. So on a 105 degree day, a z with race gas vs a z with 91 octane. You're telling me they are equal in power? Sorry I don't buy it, I know race gas makes a difference and I can prove it if anyone in CA has the same mods as I do wants to do a quick run.
Old Oct 20, 2006 | 05:02 PM
  #57
Valerie@Forged's Avatar
Valerie@Forged
Forged Internals.com
I agree with Backtuner 100%. We have tested this theory countless times on the dyno. Simply adding race fuel to an already well tuned NA or FI car will yield no whp/trq improvment.
Old Oct 20, 2006 | 07:01 PM
  #58
craigo'sznprgrs's Avatar
craigo'sznprgrs
That makes sense to me, but I don't know anything, evidently. I thought the higher the octane the more additives the gas had, lol. In essence, the higher the octane the more the "tuner" can advance timing. Hey, that is the limit of my knowledge.
Old Oct 21, 2006 | 06:43 AM
  #59
chimmike's Avatar
chimmike
again, increasing octane alone does not ADD power without a change in tune to adjust ignition timing for the additional octane.
Old Oct 21, 2006 | 11:24 AM
  #60
mario60185's Avatar
mario60185
Chicago Realtor
^^ This is not aimed only at you....Dont you people read? We have been discussing the potential of higher octane WITH a tune. And this thread is going on and on w/no point to some post, only a few guys inn this thread have actually tried it, some say theyve seen power and some said no power.
So please if you are just talking out your *** move on.
