*E-manage Ultimate Tuned* Pics and Dynos Inside
Originally Posted by Hydrazine
With the EU and our ECU's, it is indeed possible.
I noticed the same thing on my tune. By reducing timing at TQ peak it increased power at the HP peak.
Its the ECU reacting to knock and throwing everything else on the map back.
It depends on how much margin was left in the ECU timing advance capability when you originally did the tune.
If it was totally maxed out at the time of tune, then there is nothing left to advance. Maybe the Cipher timing advance can help here?
If you advance too far, detonate and force the ECU to whack timing as reactionary measure, then yes, reducing timing will give you more power because the reduction you made will probably be less than what the ECU will remove due to knock. Also, detonation is not optimal combustion so the engine efficiency will drop when it's knocking.I think it all plays into how the ECU handles knock events. I've seen ECUs that have rought and fine correction measures and the total timing formula is dependant on both. Usually, the fine correction is just an additive to the total timing profile. So, the fine correction is an instantaneous way of pulling back timing at that time, without effecting the rest of the map just to handle a brief, minor knock that does not warrant major timing changes across the map. Small pings here and there are not catastrophic so this fine correction is just for that.
Rough correction I've seen is usually when serious detonation is encountered. I've seen it done through a multiplier which is used to calculate total timing. When you knock badly, the ECU whacks the multiplier down and now all of the timing in the map has been reduced to take preventive measures so that the engine does not go boom. It's a drastic, preventative measure and it will cost you power.
The Nissan ECU may do something similar to a rough correction and whack timing across the board if it sees detonation. It may explain why you loose noticable power when you advance timing and detonate briefly. I'm just speculating here.
Sounds like Cipher does timing advance differently than EU. I'm willing to bet Cipher writes to a RAM address in the ECU which tells it to advance the timing in this area of the map. The ECU will do what it's programming dictates and will use the value as instructed. That's really how good, real-time tuning tools usually work. You're not fighting ECU to get the job done.
EU is probably a band-aid measure where it does some kind of a "trick" by altering or injecting the signal sent from the ECU to advance the timing after the ECU already did the timing calculations. The timing may get advanced for a brief period but what probably happens is the ECU recognizes the fact that it is running too much timing it and it pull it back. That is probably a safety measure in the factory programming. Again, this is all speculation on my part. But I think it's safe to say that they do the advance differently. One seems to work, the other does not
Good info guys. Thanks for sharing all that.
Originally Posted by Jeff92se
The Cipher is only able to perform Nissan Consult type changes. So it can change the base timing +/- 2 deg approx. They can't access individual ign maps and change them (yet)
Yeah unless UpRev releases some really awesome software .....
which would probably be like $1000 ...
Originally Posted by Wired 24/7
Update (this is for the benefit of anyone who happens to search for info in the future)
I just went out tonight and checked out my AFR's and **** using cipher.
The tune is LOCKED IN, STABLE AS A ROCK.
I have not reset the ECU or anything since I got the thing tuned, and I have not checked AFR until now.
It's still solid stable at 13.1-ish
In case anyone was wondering if the ECU's long-term fuel trim will negate a tune with EU, the answer is no.
The car still feels great, just as good as when it got tuned.
Also checked partial throttle... lite throttle input: AFR = 14.7
moderate throttle to WOT: AFR = 13.1- ish
Idle: 14.7 AFR
This thing should pass smog easily, even with HFC!
Idle: 14.7 AFR
execellent update!!
I have had my Utec tunned for about a year and I just got it dynoed again last week and everything was just like it was the day it was tunned. It even put down the same numbers, almost to the decimal.
Only problem is I just added a Mrev2, and didnt see anything on the dyno. The car is running a tad leaner with the Mrev, so it is doing it's job.
The dyno operator said the car is getting heat soaked, and it was pretty hot and humid, so I am hoping my higher numbers will show up when the temps come down. It still can be leaned out some more since it's right around 12.5-12.8 at WOT. The TQ looks good and everything is very smooth, it has a little hicup above 6,500 but it seems the ECU is pulling timing because of the heat soak.
Oh, and headers did not make my car any louder, just slightly deeper. You have a hard time noticing the sound difference unless you spent 2 days installing them with me.
im still not sure on this, hesitating to pull the trigger, i have a non-revup and i have intake exhaust, 5/16 spacer, want to get the mrev2 because of the gains they claim on their site, but now im hearing its not worth it for the non-revup and is a nonrev-up with a little machining, bla bla bla. . so whats the status, do it or not. I will be getting a utec tune after. or should i go with somethin like underdrive pulleys instead. i already have clutch and lightweight flywheel . basically debating on mrev2 and underdrive pulleys
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
