Best synthetic oil type...
Old Oct 27, 2006 | 12:40 PM
  #61
287HP's Avatar
287HP
Redline or Motul. Very little oil burn off from both. Excellent oils.
Old Oct 28, 2006 | 10:38 AM
  #62
nMugen's Avatar
nMugen
gaaah!!! im so effin confused, im a true car noob. i live in michigan where it snows and i might have to use my z this year in the winter till i can fix up my old accord well enough to drive. what would be a good motor oil to use for mixed weather?
Old Oct 28, 2006 | 11:06 AM
  #63
tkrienke's Avatar
tkrienke
Did you read this whole thread? Might try that.
Old Oct 28, 2006 | 11:13 AM
  #64
nMugen's Avatar
nMugen
i did read the whole thing! it seems like a deadlock between mobile 1 and royal purple. gahh, i think im gonna gow ith royal purple, more ppl seem content with it.
Old Oct 28, 2006 | 12:08 PM
  #65
sindir's Avatar
sindir
I have been using Mobil 1 5w-30 in all my cars for 4 years and never had any issues.
After reading about alot of burning issues on this and other forms, I had doubts about putting it in my new used 03 touring with 30,000 miles of dino oil already run through it.
I just changed it today after 2500(changed a little earlier than I normally would because of it being the first time synthetic was used) and the oil level had not moved. Never had to add a drop.
Old Oct 30, 2006 | 04:08 AM
  #66
nothingremains's Avatar
nothingremains
i just put royal purple 5 quarts of 10w-30 in it with a mobil 1 oil filter. how often do i need to check to see if it is burning oil ?
Old Oct 30, 2006 | 10:09 AM
  #67
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'd check every 3000 miles roughly
The dipstick is not the best... I think some people check the dipstick and think they're down 2 quarts of oil, but in reality they just aren't reading it correctly.
The only real way to know how much oil is in the engine is to do an oil change, and measure what comes out of the motor.
Old Oct 31, 2006 | 04:14 AM
  #68
nothingremains
good god is everything on this car a pain in the ***?
Old Oct 31, 2006 | 04:31 AM
  #69
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the dipstick works just fine. If you can't read it properly, you probably should not be checking it to begin with
Old Oct 31, 2006 | 04:50 AM
  #70
350Zenophile's Avatar
350Zenophile
Ran Mobil 1 in my Cobra and now for the last 10k miles in the Z. No oil consumption in either and actually dropped the operating temp in the Cobra just as much as the Amsoil I tried.
Wow. You have to be the first person in existence to not think the dipstick on the VQ35 is a P.I.T.A.
I've even tried taking it out and letting the oil in the tube drain back down before reinserting and it still comes out all streaky.
Old Oct 31, 2006 | 04:57 AM
  #71
nothingremains
yea it kinda is a pain to check. what color is royal purple oil? is it really purple?
Old Oct 31, 2006 | 09:01 AM
  #72
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
But it's not accurate to be able to say "I'm low by 0.75 quarts"
Old Oct 31, 2006 | 09:04 AM
  #73
Z1 Performance
Former Sponsor
that's why you add 1/2 quart at a time - makes it impossible to mess up then
Old Nov 7, 2006 | 04:58 PM
  #74
KnightRiders79's Avatar
KnightRiders79
just to fill all u guys in, mobile1 just down graded their oil to a level III. they no longer use a PAO oil, which sucks. its no longer any better than a normal crap oil. it is weird b/c exxon/mobile still break records with profit and they still cut corners.
Amsoil, RP, Redline, Motul FTW!
www.bobtheoilguy.com
Old Nov 7, 2006 | 08:10 PM
  #75
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
that's not the right link
here you go
http://theoildrop.server101.com/forums/ubbthreads.php
Old Nov 8, 2006 | 05:19 AM
  #76
350Zenophile
I found that thread too and it's the reason I hate going to bitog for information. It's one thing that I am in no way a chemical engineer and have difficulty deciphering all the acronyms, but even they are all in disagreement about every topic. There doesn't seem to be any consensus re: which oils are better and they spend most of the time discussing formulation when all I really care about as a car enthusiast is performance.
Isn't there a simple set of tests a third party can perform on oil to determine things like lubricity, breakdown/sludge resistance, etc.? I'm going to have to write to Consumer Reports...
Old Nov 8, 2006 | 09:26 AM
  #77
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
zenophile, the way I understand it...
synthetics are much more resistant to viscous breakdown than dino oil. that said, it seems that some 350z owners are having problems with synthetics blowing by a little too easily.
for good lubricity that you can measure using a typical oil analysis, look for molybdenum, which represents MoS2, a good high temperature lubricant.
I've seen the virgin oil analysis for motul 300v, and it's got a rediculously high moly content, which should equate to very good lubricity. Given that it's a synthetic, it should resist breakdown. As for blow-by, I have no idea.
Given the rediculous price of things like 300v, I just stick with dino oil. My motor seems to run great with it. If you change it at appropriate intervals then you will be fine.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
