Trans fluid
Old Oct 27, 2006 | 06:58 AM
larson's Avatar
larson
Default Trans fluid
I had the 6MT flushed and fluid change on the 30K service. When cold I have to force into first, second and third. Dealer said it is normal. I say it isn't. Also have a bit of grinding when getting it into second. Any help is appreciated
Old Oct 27, 2006 | 07:12 AM
csZ's Avatar
csZ
I have the same issue. I've had it in the shop twice but they say no problem found. I'm just waiting for the tranny to fail completly and then they can replace it. Good luck
Old Oct 27, 2006 | 08:34 AM
DavesZ#3's Avatar
DavesZ#3
What fluid did they replace it with, the Nissan or another brand? I recently replaced the OEM fluid in my 6MT with Royal Purple. Unlike a lot of others here that have reported smoother shifting, I've noticed mine is now extremely hard to get into 1st and 2nd when cold. It's impossible to downshift from 2nd to 1st unless I come to a complete stop.
I'm guessing the reason some people report better shifting and others report worse is in the tolerances within the transmission. Different fluids of different viscosities behave slightly different in each transmission and that may be what we're seeing.
Old Oct 27, 2006 | 09:28 AM
larson's Avatar
larson
I assume they replaced it with the Nissan fluid. I asked for synthetic but they said none was available. I have always had a little difficulty shifting when cold but this is much worse. When I first bought the car I had some problems with cold shifting but it cleared up.
Old Oct 27, 2006 | 11:18 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Definitely go with synthetic,
I recommend redline MT-90 for the 6MT
My shifting is like frigging butter
Old Oct 27, 2006 | 11:40 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Also tranny fluid needs a little time to warm up. Don't recommend hard shifts after it sat overnight.
BTW: Wired 24/7 I think you & I think alike. That or we do our research! LOL
Old Oct 27, 2006 | 12:13 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I guess we're like brotha's from anotha' motha'
Old Oct 27, 2006 | 12:56 PM
larson's Avatar
larson
Thanks Redline MT90 it will be
Old Oct 27, 2006 | 01:24 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
BTW: I mixed my Redline. 1qt MTL, 1qt MT-90, 1/2 & 1/2 of MTL & MT-90. Good luck!
Old Oct 27, 2006 | 03:02 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
First of all, tranny takes nearly 4 quarts (not 2)
But you can run straight MT-90 with no issues... it's a little heavier than MTL which I like about it... it's really personal preference
Old Oct 27, 2006 | 03:04 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I just change mind and it took three qts. Sorry if I didn't explain my mixture too well. lol
Old Oct 27, 2006 | 03:09 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Well it takes 3 and 1/8 quarts... It's best if you buy 4 quarts, better to have the right amount and have some extra rather than buy too little.
http://img164.imageshack.us/img164/7158/zfuilds2ce.jpg
Old Oct 27, 2006 | 03:12 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well I have to buy 4qts. 2-MTL & 2-MT-90. I mix 50/50 MTL/MT-90 in that last qt that I add. 1qt MTL, 1qt MT-90, ad 50/50 MTL/MT-90 for 3qts.
Old Oct 27, 2006 | 04:42 PM
DavesZ#3's Avatar
DavesZ#3
I don't think research has anything to do with the final result of how my or anybody else's transmission shifts after a fluid replacement. I read dozens of threads, hundreds of posts and even PMed a few people. In all that, there were only a handful who thought their transmission felt worse. I'm just unlucky to have to add myself to that bunch.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Ace2347
Sep 22, 2015 03:12 AM
