Just bought a quaife atb....
Old Nov 13, 2006 | 10:33 AM
AAB350z's Avatar
AAB350z
Default Just bought a quaife atb....
I have an 06 base 6spd with open differential and just bought the quaife atb. Is there anything
extra that I need to buy to have the part installed? (i.e. gaskets, or other parts?)
Old Nov 13, 2006 | 11:51 AM
meatbag's Avatar
meatbag
Youll need to get a gresse type paint so you can check the mesh on the gears and maybe a set of shims so you can correct it. DOnt need a gasket just some RTV for the cover. You will also need new bearings pressed in.
Old Nov 13, 2006 | 02:49 PM
VIZAGE's Avatar
VIZAGE
I like to here how satisfied you were with it. Which I know it will be great. But I liked to here your opinion.
Old Nov 13, 2006 | 02:51 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
God choice for your base model 350Z. You will thoroughly enjoy it. You will also need a set of bearings/races since the old ones will likely be damaged if you try to remove them. The bearings will need to be pressed in.
Your shop should have everything needed to do this. Backlash should be checked, but I have yet to see one out of spec.
Old Nov 17, 2006 | 04:47 PM
AAB350z's Avatar
AAB350z
When the part gets installed, I'll let you guys know how it is. I'm expecting to be pleased with it.
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
Fixxxercask
Nov 9, 2015 11:10 AM
