Grounding/Earthing kit question
Old Mar 19, 2003 | 12:46 AM
MATIX's Avatar
MATIX
Default Grounding/Earthing kit question
What is hte difference, or advantage/disadvantage to using the HKS grounding kit which connects all the cables to the negative battery terminal, as opposed to the insaneamine grounding kit which only has one cable connected to the negative termnal??
Heres the HKS kit
Old Mar 19, 2003 | 09:10 AM
Z'd's Avatar
Z'd
HKS uses 8 gauge wire
InSaNeAmine uses 4 gauge wire.
Arguably, there is enough direct contact with the battery ground with the single 4 gauge wire and subsequent connections to stabilize the ECU signals and achieve the desired results.
Why pay an extra $50 and be stuck with purple??
Old Mar 19, 2003 | 10:46 AM
ihatethatbobbarker's Avatar
ihatethatbobbarker
i like purple
Old Mar 24, 2003 | 04:13 PM
MATIX's Avatar
MATIX
can anyone give a little more info on the advantages/disadvantages when comparing the hks to insaneamine kit??
Old Mar 24, 2003 | 04:42 PM
lEtMeZ1's Avatar
lEtMeZ1
Probably wouldnt be a huge difference, since grounding kits offer minimal effects anyways (Not in anyway saying they are useless). I would say the only differences would be in price, color, etc. You could also brag that you have a HKS kit, while most people could only say they have a DIY kit!
Old Mar 24, 2003 | 04:52 PM
ihatethatbobbarker
thats one of my biggest reasons
and i thought Purple would be cool with my car color
issyz
Jul 2, 2017 03:04 PM
samansharif
Sep 25, 2015 12:31 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
