Tweaked My Ecu -- Wow!!
Old Mar 19, 2003 | 02:17 PM
Oh4aZ's Avatar
Oh4aZ
Thumbs up Tweaked My Ecu -- Wow!!
Well, I am lucky. An acquaintance of mine has the "Consult" device which is the device used to program the ECU. He plugged it in and made the adjustments.
Here is a print out:
Corrected IGN TIM: 5 degrees
ENG SPEED: 838 RPM
Corrected IDL RPM: 175 RPM
COOLAN TEMP/S: 192 Degrees farenheit
CLSD THL POS: ON
IGN TIMING: 17BTDC
I currently have Stillen Exhaust, Injen CAI and grounding kit. These mods combined with the tweaked ecu result in better low end due to the more lean air/fuel mixture and a lot better top end due to the advanced timing. I don't recommend people at sea level modifying the air/fuel mixture as I believe that the ECU is already tuned for sea level. I did this because I am at 6,000 FT elevation and wanted my car to run a little more lean.
On a side note, my gas mileage did go down by about 3 mpg, but I am okay with trading better performance for a little less gas mileage.
Old Mar 19, 2003 | 02:40 PM
rickski's Avatar
rickski
Any performance stats?
Old Mar 19, 2003 | 02:42 PM
Oh4aZ's Avatar
Oh4aZ
I am not into dyno'ing my car as much as I am interested in getting good track times. I have a date with the 1/4 mile track on 3/30. The general rule of thumb is add .15 seconds for every 1,000 feet elevation to your quarter mile times from the base sea level times. I am shooting for 14.4 - 14.6 at this elevation.
Old Mar 19, 2003 | 02:48 PM
fdao's Avatar
fdao
Oh4az,
So you advanced 5 degrees? Was your ign timing at 12 degrees prior?
Old Mar 19, 2003 | 02:51 PM
Oh4aZ's Avatar
Oh4aZ
Originally posted by fdao
Oh4az,
fdao, unfortunately, my friend didn't do a printout before he tweaked the ECU so I am not sure what it was before. I was pretty bummed that he forgot to do that but I didn't want to say anything since he hooked me up bigtime.
Old Mar 19, 2003 | 03:33 PM
PhoenixINX's Avatar
PhoenixINX
Being that you can't just PLUG in a consult device to modify it... mind explaining how he cracked the coding so easily... The entire ECU is VERY encoded, very similarly people have spent YEARS trying to crack the `96 OBDII Z32 TTs ecu with no luck...
Old Mar 19, 2003 | 03:36 PM
Oh4aZ's Avatar
Oh4aZ
He is a certified Nissan Master Technician. He didn't have to crack anything, and yes, all he did was plug in the consult device and made the modifications.
Old Mar 19, 2003 | 04:33 PM
Ricky's Avatar
Ricky
Any differences in driving it? Feel more power? softer idle? ect ect
Old Mar 19, 2003 | 04:37 PM
Oh4aZ's Avatar
Oh4aZ
Yeah, the idle is a little higher now. I feel improvements both low end and high end but more so on the high end. Pulls harder now.
Old Mar 19, 2003 | 05:09 PM
webcarconnection's Avatar
webcarconnection
Other people here went to the dealer and advance the Ign. timing. in your case, I notice that your friend adjust more stuff...rigth. ask your friend if we can only advance the Ign. for performance or is more to it?
Thanks
Old Mar 19, 2003 | 07:22 PM
PhoenixINX's Avatar
PhoenixINX
ehhhhhhhhh okay
he did your timing... ok.
No remapping of the fuel curve. I got ya!
Old Mar 19, 2003 | 07:42 PM
Oh4aZ's Avatar
Oh4aZ
yes, advanced the timing and adjusted the a/f mixture.
Old Mar 19, 2003 | 09:12 PM
krinkov's Avatar
krinkov
what gas do you guys get up there 91? 93?
Old Mar 20, 2003 | 06:05 AM
Oh4aZ's Avatar
Oh4aZ
As far as I know there is ONE station in town that has 93 -- and that is the only gas I put in my Z.
Old Mar 20, 2003 | 10:27 AM
STLZ's Avatar
STLZ
There is no way to mod the air/fuel mix the computer will just learn what you have done and adjust. My tech says the classes he has attended for the 350z they tell him it will just go back to the regular timing of 12BTDC, because you are not turning any carb. Check and see if it stays or not I would be courious to see what happens down the road.
Old Mar 20, 2003 | 10:54 AM
stx's Avatar
stx
Not if he changed the program in the EEPROM. That is the chip that holds the programing for the CPU. The CPU will just try to adjust to what ever it is programmed to from the EEPROM. The CPU doesn't come up with numbers on its own.
Old Mar 21, 2003 | 06:35 AM
webcarconnection
yeah... thats why I ask what the friend do or adjust in the ecu or cpu or eeprom... whatever he adjust!
Old Mar 24, 2003 | 07:09 PM
can350z's Avatar
can350z
Default Any more updates????
Very curious to hear any more positives about this and any other experiences with other members....
Old Mar 28, 2003 | 12:35 AM
S12 driver's Avatar
S12 driver
Have anyone used a o2 simulator in your Z? They are used to simulate the o2 sensor so the ecu won't know the change you made, everything will look normal to the ecu. (I'm not sure how strict now the ecu is, if it's just concerning with emmission then this might work. If not, maybe it can be used in combination w/SAFC2 to fool the ecu completely) If that can be used, then the advanced timing, cai, and exhaust mod should make decent power, and the power would stay. Just a thought. o2 simulator for WRX
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
