Silly question re: built motors
Old Nov 18, 2006 | 05:31 AM
MustGoFastR's Avatar
MustGoFastR
Default Silly question re: built motors
I see the terms "long block" and "short block" being thrown around alot and I have no freaking idea what the difference in between the two. Anyone care to explain?
Old Nov 18, 2006 | 05:32 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
The long block is a little longer than the short block.
Old Nov 18, 2006 | 05:33 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
I think the long block includes the heads, valves, cams... etc along with the bottom end with the pistons, crankshaft, cylinders.. etc
The short block is just the bottom end IIRC
Old Nov 18, 2006 | 06:19 AM
Z04's Avatar
Z04
The short block engine is normally just the block with pistons and a crank, and no heads or intake. The long block is the full engine, everything on it
Old Nov 18, 2006 | 07:08 AM
bleufiend's Avatar
bleufiend
^^^^ The 2 posts above are correct.
I work at nissan, when we order a long block it comes with the head and block, all you have to do is swap over the accessories from your old engine(I.E. alternator, power steering pump,a/c compressor etc) and a couple of sensors and drop it in the car.
If you get just a short block then all that is is the block with the bottom end in it (I.E. crank, rods, wristpins, pistons, piston rings). And you have to swap over the head or heads with all accompanying valvetrain hardware including the timing chain or belt with there sprockets and tensioners on the front of the engine before putting on any accessories.
Old Dec 5, 2006 | 07:47 AM
MustGoFastR
Forgot I asked this question until just now. Thanks for the clarification, guys.
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Nov 9, 2015 11:10 AM
