Need Help Please !!!!!!!!!!!!!!!!1
on
I just recently had a competition clutch stage 4 and installed a new tranny at a nissan dealership. Anyway the clutch chatters horrible at idle when clutch is not engaged, also when moving up to 3 thousand rpm. Please tell me is this normal. I called competition they said it is normal and talk to a speed shop but everyone else is saying it isnt
Thank you
Thank you
on
Yes normal, a aftermarket performance clutch/ flywheel does not have the dampening material a stock more comfortable clutch/flywheel will. A couple things you can do is raise your Idle to 900 to prevent the chatter and try to drive the car more sporty like to stay out of the chatter zone.
When we go for performance we sacrifice comfort.
on
Thankz Redline For The Reply As For My Title Wired It Is Relevent As I Am In Need Of Help Due To The Fact If My Tranny Was Messed Up My Warrenty Will Be Ending Soon But I Appreciate The Input Thanks Guys
Dr. Wired
By the way, turn off caps lock
on
just so you know I am in marketing and actually that title says a million things it will catch more attention by someone not knowing what it is. Then if someone was scrolling down and saw need tranny help more people will view the fourm then if i did put tranny help. It's ok to be wrong
