Dipstick Picture please
Old Dec 7, 2006 | 04:12 PM
blackmax01's Avatar
blackmax01
ericjackson - I am aware that the car is supposed to sit to check the oil =P It was more disbelief that my car's oil level could be low that caused me to doubt the dipstick reading.
Especially after reading about people that have had oil consumption trouble etc...Sometimes you just doubt yourself and want to err on the side of caution.
Old Dec 7, 2006 | 04:21 PM
HighwaySpeed's Avatar
HighwaySpeed
Exclamation
R
T
F
M
Old Dec 7, 2006 | 08:06 PM
bhendjol's Avatar
bhendjol
achoooooo
Originally Posted by vo7848
We'll make it easy
Old Dec 7, 2006 | 08:23 PM
03performz's Avatar
03performz
The Z's dipstick is the worst ever. I could see you having probs. w/ it. Just wait about an hour after shutting off the car and check it then. For some reason it seems as thought the oil takes longer to drain down into the pan w/ this car. Good luck and don't worry about the flamers...cuz...well..they're flamers.
Old Dec 7, 2006 | 08:37 PM
chunpiu's Avatar
chunpiu
Man, i laugh so hard on your pic. That is a such a good pic, easy to understand.
Old Dec 8, 2006 | 12:33 AM
undrgnd's Avatar
undrgnd
Great entertainment. This proves you don't need any common sense or have to know anything about cars to get a driver's license.
Old Dec 8, 2006 | 04:46 AM
jedicowboy's Avatar
jedicowboy
Originally Posted by blackmax01
I can understand why Jedicowboy could be asking for a picture...
1st the dipstick is fkn retarded to get out and put back in so you worry that you might have hit the dipstick as it's coming out or whatever. *I have a G, but I'm guessing it's exactly the same on the Z*
2nd My oil level was so low I was only getting streaks of oil that ran from the H mark to the tip, but I wasn't sure if I was full or just getting residue on the dipstick. A picture could have helped at the time. I ended up pouring in a quart to see what it would do to the oil level and it turns out that I was dangerously low. At the time I figured if I was reading the dipstick correctly and I poured too much oil in, I could just drain a little out. Luckily (or unlucky I was running low) I made the right choice, but again, if I would have seen a pic of what the dipstick looked like, with the oil on, it probably would have eased my mind a bit.
**I have to add, I have had several cars before this one, and changed my oil etc...you always worry especially when it's a newer car that you're not familiar with. Not all cars are exactly the same..my .02**
So Jedicowboy, why do you want a pic???
I don't have a picture, but if that helps, cool...
Thank you, blackmax01.
To all of the other zit-faced teenagers on here driving their first real sports car and having multiple my-space browsers open, that have posted in this thread...thanks for nothing.
This is my seventh car the third of which to have only two seats. I do all of the maintenance work myself, but like to know exactly what I a doing first.
All of these people talking about low oil in the '06s, having a poorly designed dipstick and dealers not fessing up to a problem got me thinking that it would be great to see a picture of what the proper oil level looks like on a Z dipstick. I have read the manual cover to cover and the picture in there sucks.
Some of you need to loosen your skintight neoprene shirts out there. This should be an information forum. Not a chatroom. Get a life. Also, because of the all-knowing jackasses on here with the sole intention of boosting their post counts the search archives are full of posts telling people to use the search engine. Go over to corvetteform.com if you would like to see how a real forum works. People sharing information and actually contributing. No disrespect to the mods here. I understand that is just a different crowd.
Old Dec 8, 2006 | 05:37 AM
THE TECH's Avatar
THE TECH
Feel free to go back to the Corvette forum and troll over there. You were the one who brought the disrespect in the first place.
Old Dec 8, 2006 | 05:42 AM
sumfknguy's Avatar
sumfknguy
jedicowboy..
I can snap a pic tomorrow if you still want to see this. But like others have said here, let it sit for a few hours (I check first thing in the morning) and then check it.. it’s a lot easier to read this way…
and yeah, some of the guys here can be real morons, but its seems to be the norm to have some clowns patrolling the threads looking to make an a$$ out of people (or better yet themselves), but for the most part, this place is excellent for information and assistance.
nice Vette btw...
Old Dec 8, 2006 | 05:55 AM
03BrickyardZ's Avatar
03BrickyardZ
Originally Posted by sumfknguy
jedicowboy..
nice Vette btw...
You're supposed to read the levels while the motor is still warm.
I agree though, the dipstick sucks. It is very difficult to read. My recoomendation is run the car until your oil is up to operating temperature. (Oil takes longer to warm up than water, so don't go by your water temp gauge.) Shut it off, wait ten minutes, and then keep taking readings untill you get one that you feel is accurate. A good rule of thumb is, if there is only a little oil, its probably transfer. If there is a lot with a little missing, some probably scraped off. It's still a pain in the neck to read.
Old Dec 8, 2006 | 06:21 AM
mikead_99's Avatar
mikead_99
Dude, that is wrong. You change it warm so it drains faster because it flows better when warm. Temp doesn't matter in the least when checking it and as others have mentioned, it takes quite a while for it all to drain back into the pan. If you really want to have an idea about the total volume of oil in the system, you wait until as much as possible is in the pan where the measurement is made. Overnight is a good suggestion.
To OP, you should be able to get a good line across the hatch marks on the stick if it has settled and the level is good.
Old Dec 8, 2006 | 06:49 AM
VO...'s Avatar
VO...
Administrator
Not quite buddy. We're the same age. BTW, nice house.
Not knowing how to read oil levels doesn't quite qualify you as a do-it-your-selfer mechanic. How's that Starbucks latte?
Now you have a pretty picture you can paste inside your manual.
Perhaps you should stay there.
Old Dec 8, 2006 | 07:27 AM
jedicowboy's Avatar
jedicowboy
Thanks for the input everybody.
I just want to set the record straight that I am not some kid with a co-signed car that doesn't know how to put air in the tire and then would drive on a flat rim. I know quite a bit about vehicles, have worked on my C5 Corvette quite a bit. Not just changing oil either. We are talking suspension swap, rocker arms, intake and even some electrial work just to name a few. I am by no way an expert mechanic. I do enjoy a good Latte every now and again though. I prefer Seatles Best to Starbucks though. I do know enough to ask a question about something that I am unsure of too. ie:reading this pos dipstick.
Not trying to be a troll...
cheers
Old Dec 8, 2006 | 08:38 AM
VO...'s Avatar
VO...
Administrator
cheers
Good sport We're just giving you a hard time. Call it a "right of passage". Keep your skin thick and you'll fit in fine around here. BTW, the pics of the vette are sweet. Good luck with the Z.
Val
Old Dec 8, 2006 | 10:38 AM
InsaneChink's Avatar
InsaneChink
someone should photochop the enzodude popping out of the dipstick.
Old Dec 8, 2006 | 12:39 PM
jedicowboy's Avatar
jedicowboy
See? I told you the picture in my owner's manual sucked
Old Dec 8, 2006 | 01:07 PM
VO...'s Avatar
VO...
Administrator
apex locator
Jul 23, 2021 02:27 AM
Depravity
Oct 1, 2015 04:49 PM
