Nitrous and Procharger
Old Dec 13, 2006 | 02:28 PM
ABL 2 FLY's Avatar
ABL 2 FLY
Default Nitrous and Procharger
Well I didnt know if I should put this under Forced Induction or Nitrous so let me know if I should move it. Anyways I wanted to know if anyone has had any expirience with putting a 50 shot of nitrous on an ATI Procharger. I have a built motor and am only running 15psi. Would it be safe? Any ideas or recomendations would be appriciated.
Thanks
Old Dec 13, 2006 | 02:44 PM
ABL 2 FLY's Avatar
ABL 2 FLY
My mechanic (big time drag racer) said it would be a huge help. I would just need to tune 4 it... IDK has anyone done a small shot and a supercharged or turbo car?
Old Dec 13, 2006 | 02:45 PM
Barzten1's Avatar
Barzten1
I was curious about the same thing with the Vortech. I want to do this when I build my motor in February.
Old Dec 14, 2006 | 07:09 AM
THE TECH's Avatar
THE TECH
Originally Posted by jonb7007
I would never run Nitrous.. IMO.... your just asking to blow...
Sorry, but that it just an ignorant statement. When run properly, it will be as safe as any other mod.
Old Dec 14, 2006 | 07:12 PM
Mc556's Avatar
Mc556
+1
Old Dec 14, 2006 | 07:49 PM
HDPDZO6's Avatar
HDPDZO6
IGNORANT HUH.. You better watch who your talking to .....
But, your statement is ignorant. Just a little bit of research proves the contrary to what you wrote.
Old Dec 14, 2006 | 10:18 PM
DSport G35's Avatar
DSport G35
Good topic, I have been wondering the same too. If any of the pros(Sharif, Sam, etc...) can chime in with some info on this setup that would be great. Shot amount?, what gears to run in?, best setup(wet vs. dry, throttle switch or button?) with a blower, Vortech or ATI...
Bump!!
Old Dec 15, 2006 | 06:09 AM
Old School's Avatar
Old School
Shift_Boost
tuning becomes a major issue when combining boost with spray. A safer route would be to spray the aftercooler, but a 50 shot will do wonders when sprayed into the motor on a SC'd car. 2 step colder plugs is a must....platinum is a big no no with nitrous, so if you don't already have iridium, get em. What type of management do you have? If you are running UTEC, I'd make a separate map with more timing pulled when you know you're gonna spray. As long as you're built, you shouldn't run into any problems if everything I mentioned is in place. Good luck...nitrous is fun!
NissanZcrazy
Sep 23, 2015 07:59 AM
jesseenglish
Mar 7, 2004 02:23 PM
JoeAE2005
Jul 10, 2003 06:59 AM
McDan
Jun 9, 2003 12:02 AM
austin350z
May 4, 2003 06:51 PM
