WTF is this ????
Old Dec 20, 2006 | 12:44 PM
TayTaythatsme04's Avatar
TayTaythatsme04
its very thin looks like aluminum, the filter neck caught all of it. and yes this is the first time it has been opened up. Im in final stages of finish my turbo install. The car a little under 25K
And yes Im a little nervous
Thanks
T
Old Dec 20, 2006 | 12:52 PM
mdracer76's Avatar
mdracer76
Does a magnet stick to them?
Old Dec 20, 2006 | 01:03 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
From the thickness of it, i would say it's a shim of some sort, but i couldn't tell you where from.
Old Dec 20, 2006 | 01:26 PM
THE TECH's Avatar
THE TECH
Did you buy the car new? If it was used, do you know all the history behind it?
Old Dec 20, 2006 | 01:32 PM
TayTaythatsme04
I brought it used 04 the gentlemen that own it had many other cars and didnt drive this one at all, it was in a garage for almost a year not moved. I brought it in Jan 06 and its been babied, no track, no drag, just alittle fun every once in a while. But in no means is it driven hard.
I have all the history on the car, the guy owns a DB9 and some very nice porches. And he is very clean and caring with cars. So I know and have the proof I brought a great car from him
T
Old Dec 20, 2006 | 03:39 PM
usafmech's Avatar
usafmech
+1 At least this will determine the type of metal.
Old Dec 20, 2006 | 06:00 PM
Eazzy's Avatar
Eazzy
Thanks
T
Babbit shavings from a rod or main brg are thin like razor blades and non magnetic
Old Dec 20, 2006 | 08:12 PM
TayTaythatsme04
so is it normal or should I be worried ?
T
Old Dec 20, 2006 | 08:21 PM
Eazzy's Avatar
Eazzy
T
People over react but in this case u have to Identify were it came from. If I could hold them in my hand I could narrow it down.
U need to find someone that isnt full of **** and trying to prove something that knows the inside of the Z Motor.
Fact is, There just arent that many places it can come from once u determain the type of metal --- Its a simple puzzle for someone that knows machines and can see it first hand.
U need peace of mind
Old Dec 20, 2006 | 08:24 PM
Eazzy's Avatar
Eazzy
Hell ---If nothing else, send a couple pieces USPS Priority to one of the builders here in the forum
Old Dec 20, 2006 | 08:29 PM
Eazzy's Avatar
Eazzy
I keep thinking of things ---It could be so simple as a sloppy Post Machine Flush from the Factory in which case ---No Worrys. But u HAVE to know for sure.
Old Dec 20, 2006 | 08:38 PM
MIAPLAYA's Avatar
MIAPLAYA
Taytay, try calling Danzio Performance in Lake Elsinore. See if you can swing it by there. They've built a few VQ35s now and should be able to tell you what it is...
Old Dec 20, 2006 | 08:59 PM
TayTaythatsme04
I forgot about about them . . . they never answer there phone but I swing by there tomarrow
Thanks for the reminder MIA
T
Old Dec 20, 2006 | 09:04 PM
MIAPLAYA's Avatar
MIAPLAYA
T
No worries bro... Chris Muzio over there should be able to tell you exactly what it is. If he can't I would start worrying then..
Old Dec 20, 2006 | 09:28 PM
MR_X's Avatar
MR_X
I finishing up my Tn kit and Im clean the last bit of oil off the pan with the old sealant. In front of the screen in the oil pump neck there is this stuff. Looks like a cut up coke can in really small pieces.
WHAT IS IT DOING THERE ?
Thanks
T
I'm just going to throw something out, may be some one can put their in this but it is not meant to be a anwser to this, just something to add to the mistery.
By comparing the material with the "CTRL" key of the keyboard in the first pic, I will say that this is pretty thin material and they have a groove on them. The groove in them is what bugs me. Remind me of the oil journal of a rod/main bearing. I seen what a spun bearing looks like if its driven for a while. It gets stretch out and thin like this. This is not a sure thing just something that reminded me of my Honda days.
If this is the case, it doesn't mean it came from your current motor. Do you have the car full history report like the one you get at the dealer that tells you everything that cars has been worked on (at least I get this every time I take my car in for service)?
Old Dec 20, 2006 | 11:46 PM
TayTaythatsme04
Im going to find a local opinion, but Im hoping its just from when the car was first made and driven. This is the first time the pan has been opened since it was made
T
Old Dec 20, 2006 | 11:56 PM
silver nismo's Avatar
silver nismo
Originally Posted by THE TECH
Does the TN kit require you to do any tapping of the block for oil? Those look like some sort of metal shavings from using a drill.
Thats exactly what i was thinking i got used a normal oil after building my angin and doing the port and polish for 200 km and then changed it and it had a lot of iron shavings but too small u will hardlu notice but i was thinking maybe thats what it is and if the car is runbning and its fine and no heat or big oil loosing is happening then u should be good...
Old Dec 21, 2006 | 12:18 AM
  #38
TayTaythatsme04
these shavings where all stuck in the neck in front of the mesh to stop this stuff from getting sucked up in to the pump.
So who knows how long they have been there. And for the TN tap I only tap the sender unit, not the upper pan, Im using a AAM spacer, so its not from that. Im also not finished with my install
T
Old Dec 21, 2006 | 02:26 AM
  #39
striker27's Avatar
striker27
That was me I sabotaged your car after you would not sell me that damn spacer. Let me tell you right now you will soon have nothing but problems I have cursed that thing real bad man. With some nasty MOJO!!!!!!!!!!
Old Dec 21, 2006 | 07:22 AM
  #40
davidf's Avatar
davidf
I have to agree here with Mr.X, that groove buds the hell outa me. Have a dealer run your vin. this should give you any dealer maint./warranty service history. Those grooves are very questionable. You might even slip into the nissan shop and ask a good nissan tech if he recognizes them.
