Has anyone had to upgrade the alternator for lots of mods
Old Jan 6, 2007 | 03:13 PM
Jokestrap's Avatar
Jokestrap
Default Has anyone had to upgrade the alternator for lots of mods
Have any of you guys had problems with the alternator not holding up under load with 550-600whp and a lot of stereo stuff etc???
Maybe I just had a "bad" alternator...
Thanks.
Old Jan 6, 2007 | 04:00 PM
davidf's Avatar
davidf
Do they make one bigger for the VQ?
Old Jan 6, 2007 | 05:35 PM
dTor's Avatar
dTor
I've seen one other guy either on here or driver that had an upgraded alt. I don't remember how many amps it was, but he was selling it, USED, for about $700 IIRC. They are hella expensive to have made. A much cheaper route would be to custom fab a bracket for a GM alt.
As to your other question, I don't see how the amount of hp you're making would relate to your alternator running out of current capacity. Your alt doesn't care if your making 600 or 60 hp. As long as it's turning it's making power (albeit it will be happier at higher rpms).
What do you consider to be "a lot" of stereo stuff? How many watts continuous (not what your amps are rated, but how much do you think you're actually using)?
I have heard of our cars sputtering with an aftermarket stereo turned up a bit. It happened to me for about a week. Then I "debridged" my component set and I was able to turn the stereo up much higher before it sputtered. I then installed a grounding kit (custom made 10 wire ) about a week later and my car has not sputtered since. The gains on the amp have not been touched throughout the process, either.
Old Jan 6, 2007 | 06:25 PM
Jokestrap's Avatar
Jokestrap
Oh no, hp has nothing to do with it. It has to do with all of the stuff that requires additional eletro to make it all go at high whp and that including a highly stressful stereo system.
Old Jan 7, 2007 | 04:58 AM
Jokestrap's Avatar
Jokestrap
I should have read your post completely. So, you are telling me that your plugs would not get enough spark and would run rich and sputter when the stereo was turned up?
Old Jan 7, 2007 | 07:46 AM
MR_X's Avatar
MR_X
so you think the problem to this is your alternator? Didn't you unplugged the stereo to see if that fix the problem?
Old Jan 7, 2007 | 07:57 AM
dTor's Avatar
dTor
It could be that, but something was definetely being robbed of power. It could be the ECU, Ignition system, a sensor perhaps. All I know is that when I reduced the current draw and improved the grounding, the problem went away.
Old Jan 7, 2007 | 10:19 AM
Jokestrap's Avatar
Jokestrap
Basically, I pulled the plugs and they were black and two not firing. I replaced them and it ran fine. For awhile, until the new ones fouled as well. Of the three culprits for misfires (fuel, spark, compression) it was obvious that spark was the issue. It was thought to be coil packs, or crank angle sensor. However, upon replacing the plugs, it ran great. It has to be due to insufficient spark. Runs rich until it fouls the plugs and here we go again. I did disconnect the stereo and it simply just took longer for the plugs to go again. I am having the alt upgraded and replacing my bat. That's all I can think of. The system for engines is completely logical. This is all I can logically come up with at this time.
Old Jan 7, 2007 | 10:21 AM
Jokestrap's Avatar
Jokestrap
What are your major mods, just so I can see if your situation is relative.
Old Jan 7, 2007 | 02:08 PM
MR_X's Avatar
MR_X
I wonder how rich your tune is?
Old Jan 7, 2007 | 05:09 PM
rocks's Avatar
rocks
If your plugs are fouling that fast what is your a/f ratio?
Old Jan 8, 2007 | 01:22 PM
Jokestrap's Avatar
Jokestrap
12.96 to 13.56 at idle.
Old Jan 8, 2007 | 01:25 PM
Jokestrap's Avatar
Jokestrap
Remember, the stereo amps cut out when I get on it (WOT). So it's possible that the whole system is running low on juice and the more I stress the system, the worse it is.
Old Jan 8, 2007 | 02:45 PM
rocks's Avatar
rocks
What is your a/f under load?
Old Jan 8, 2007 | 02:53 PM
Z-CRA-Z's Avatar
Z-CRA-Z
Just put a Kinetix backup battery with an isolator switch and you shouldn't have power issues.
I would also put in an Optima Yellow Top for good measure.
Old Jan 8, 2007 | 03:15 PM
Jokestrap's Avatar
Jokestrap
Ya know, I really don't know. I will have to call the shop and have them pull up my chart. I'll let you know. Mark @ SGP Racing did the tune. I am sure it is good but I'll post it up for you anyway.
Old Jan 8, 2007 | 03:17 PM
Jokestrap's Avatar
Jokestrap
Got the Optima Yellow the other day. I could go the backup route but I really don't want to add anymore weight. Appreciate the post though.
Old Jan 8, 2007 | 06:33 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
why on earth is it so rich?
you should be in the mid 14's to high 14's at idle
Old Jan 8, 2007 | 07:43 PM
Cannysage's Avatar
Cannysage
you altenator effects your A/C and your stereo.. not your power output.. wonder if a beefy alternator can help your ac to be colder somehow.. AC in new cars still usues freon, right?
Old Jan 9, 2007 | 03:37 AM
Jokestrap's Avatar
Jokestrap
He says he doesn't want to lean it out until he can figure out why it fluctuates so much and why the stereo cuts out under load. Even that rich, it should not foul the plugs in 200 miles right?
dcains
Nov 11, 2015 11:36 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
