Finding odd size automotive bolts
Old Jan 8, 2007 | 04:58 PM
meatbag's Avatar
meatbag
Default Finding odd size automotive bolts
Im trying to find a grade 12.9 M12x1.25 partialy threaded socket head cap screw in a blue or some other corrosion inhibiting coating.
Tried mcmaster-carr and google.
Old Jan 8, 2007 | 05:36 PM
jtabraham's Avatar
jtabraham
Did you try looking for one in type 316 stainless? That would be as corrosive resisitent as you can get, and are more common than special coated hardware.
Old Jan 9, 2007 | 08:50 PM
overZealous1's Avatar
overZealous1
try and check with your local industrial bolt supply houses. what is it for? how many do you need? if you pm me tomorrow to remind me, i can call my bolt supplier and check, need to know the length too though.
Old Jan 9, 2007 | 08:54 PM
meatbag's Avatar
meatbag
Its for mounting a set of brake calipers to the brakets.
Length i need is 60mm. I tried one local place i know of but they just had plain steel.
McMaster-Carr has the same steel ones but nothing with a finish.
Metric Class 12.9 Alloy Socket Head Cap Screw M12 Thread, 60mm Length, 1.25mm Special Pitch
I wanted to find something thats not going to get surface rust.
Old Jan 9, 2007 | 08:58 PM
overZealous1
zinc (gold) finish should be easy, not sure about the blue though. the guys i use have a 20,000 sq ft warehouse filled with nothing but bolts, and access to basically every manufacturer in the u.s. they are the only ones who found the bolts needed for my head mod (that came from germany). if it is made, they can get it.
Old Jan 9, 2007 | 09:00 PM
meatbag's Avatar
meatbag
Anything will be fine with me as long as its the right grade. I have one other local place im going to try and find that someone was telling me about.
Old Jan 9, 2007 | 09:20 PM
meatbag's Avatar
meatbag
Only need 4 bolts lol
Old Jan 9, 2007 | 10:24 PM
UnderPressure's Avatar
UnderPressure
www.fastenal.com
Old Jan 10, 2007 | 04:08 PM
meatbag's Avatar
meatbag
No luck.
wanderingstuden
Jan 28, 2016 07:03 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
