Axel ratios?
Old Mar 28, 2003 | 07:11 PM
damit's Avatar
damit
Default Axel ratios?
I read a thread from another user on another forum saying that a touring 6mt has a 3.36 axel ratio and all other have the 3.54
He stated that the other models have more "top end" and they launch better i do not understand this. Can anyone please help clarify it. thx
Old Mar 28, 2003 | 07:33 PM
krinkov's Avatar
krinkov
Axle ratio is the final drive ratio, or gear ratio thats in your rear end. This is the first I had heard that anything but the automatic had a different ratio, I think he was confused.
Also what he calls top-end, is usually called low-end, but yes, a numericaly higher gear ratio(refered to as a "lower" gear even though numerically higher) is typically better for acceleration since it creates more torque multiplication.
Old Mar 28, 2003 | 07:48 PM
damit's Avatar
damit
Thanks again you made it clear that the 6mt touring has the same ratio as the other models and only the auto's are different.
Old Mar 28, 2003 | 08:18 PM
Intrepid's Avatar
Intrepid
See Here:
https://my350z.com/forum/showthread....threadid=11405
Z'd's Avatar
Z'd
Manual transmissions have a gear ratio of 3.538
Autos have a gear ratio of 3.357
These specs offset against the transmission gear ratios:
Manual- 1st:3.794 to 6th: .794
Auto- 1st:3.540 to 5th: .834
Old Mar 28, 2003 | 08:21 PM
FLY BY Z's Avatar
FLY BY Z
I think he is saying the models with more gearing (low gear/high number) do indeed have a higher top speed (unrestricted) as they will better utilize top gear by pushing the revs into higher RPM's with more power since the car will be drag resistant before it tachs out as well as giving it the obvious benefit of better acceleration. I do not think the terms topend and low end were confused at all. Yes, as krinkov said, the manuals all have the same final ratio in the rear end at 3.55 and the autos have a higher ratio (lower number).
Going with a lower gear will increase top speed AND acceleration until you install the gear that redlines sixth at your given horsepower output. A TT Z would redline 6th with less gearing than a stock powered Z.
etkms
Jun 19, 2022 06:30 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Shane86
Sep 17, 2015 05:33 PM
OCG35Coupe
Jul 22, 2003 02:44 PM
