how do you tell from a 3.9 gears from a 3.5 gears
Old Jan 9, 2007 | 07:14 PM
o snap its eric's Avatar
o snap its eric
Default how do you tell from a 3.9 gears from a 3.5 gears
how do you tell?
Old Jan 9, 2007 | 07:17 PM
sentry65's Avatar
sentry65
the burninator
by just looking at them? the 3.9 would have fewer teeth
if they're installed, you can tell if you redline at 35mph at 6600 rpm in 1st gear or if you cruise the highway at 80mph at 3300 rpms in 6th gear
Old Jan 9, 2007 | 07:28 PM
Jun's Avatar
Jun
you will find yourself shifting a lot sooner.
Old Jan 9, 2007 | 08:02 PM
UnderPressure's Avatar
UnderPressure
More teeth, not less.
Count the teeth on the ring and divide that by the number of teeth on the pinion.
Old Jan 9, 2007 | 08:37 PM
overZealous1's Avatar
overZealous1
just lift up the back of the car (put it in neutral) put a mark on the tire and ground or fender, then a mark on your driveline and the pumpkin. rotate the tire one exact full revolution, and count how many times your driveshaft turns.
out of the car, do what underpressure said. divide the number of teeth on the ring gear by the number of teeth on the pinion.
sherm
Apr 11, 2020 05:21 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
