OEM oil Filter good??
Old Feb 8, 2007 | 06:05 PM
halfass872's Avatar
halfass872
Default OEM oil Filter good??
I know i'm gonna get flamed all to hell but here it goes!! Bought my Z with 32000 mile on her, and have only used Amsoil and K&N oil filters since i got her. I'm really **** about oil changes. I know i don't need to, but i still change every 3000. (i know i'm wasting money) My question is.....is K&N that much better then the OEM filter that i should use it. Or should i stick with OEM and save the money since i am still changing at 3000? Thanks!!
Old Feb 8, 2007 | 06:40 PM
Cannysage's Avatar
Cannysage
there's absolutely nothing wrong with oem.. oem is great. I'd suggest aftermarket filters, only if you go synthetic to take full advantage..
Old Feb 8, 2007 | 06:42 PM
Cannysage's Avatar
Cannysage
I change my mine every 6k miles, unless I drive like a madman.
Old Feb 8, 2007 | 06:52 PM
Mike Wazowski's Avatar
Mike Wazowski
OEM is good. I use K&N however and Royal Purple oil.
Old Feb 8, 2007 | 09:14 PM
derek173's Avatar
derek173
purolator oil filters are great and cheaper then both
Old Feb 9, 2007 | 04:26 AM
NaNa-Papa-J's Avatar
NaNa-Papa-J
+1
I use the Purolator PureOne filter along with Royal Purple. I honestly heard and felt a much smoother engine in my baby the first time I used Royal Purple.
Old Feb 9, 2007 | 02:54 PM
nismology1's Avatar
nismology1
The OEM 350Z filter (65F00) is trash. A couple maxima guys (the maxima VQ35 uses the same oil filter) cut it open and found it to have cardboard end caps. Many have upgraded to the VQ30 oil filter (9E000 w/metal endcaps) which happens to be longer or to good aftermarket filters like K&N, Amsoil, Mobil 1......
Old Feb 9, 2007 | 02:59 PM
Kevins350z's Avatar
Kevins350z
K&N + Royal Purple FTW
Old Feb 9, 2007 | 03:06 PM
redlude97's Avatar
redlude97
I guess FRAM filters must be great too then http://www.6mt.net/forum/showthread....hlight=pureone I use the pureone pl14610, which is slightly longer. Just make sure you get the newer version where the perforated metal extends the entire distance of the filter
Old Feb 9, 2007 | 03:11 PM
genegoesfast's Avatar
genegoesfast
the serivce manager at a local dealership told me that the oem filter has a valve that traps oil for later startups. Flapper valve he called it. He said it was due to the vq35's sideways oil filter placement.
Old Feb 9, 2007 | 04:58 PM
Mazinger Z's Avatar
Mazinger Z
I use the long OEM oil filter. Don't know if it's better or worse but haven't had problems w/ it so far.
Old Feb 9, 2007 | 06:19 PM
nismology1's Avatar
nismology1
That's the 9E000. Good choice...
Old Feb 13, 2007 | 01:23 PM
Mathys's Avatar
Mathys
This 9E000, which Nissan models have this filter?
Old Feb 13, 2007 | 01:36 PM
sentry65's Avatar
sentry65
the burninator
someone should cut open one or a used one and take a look inside
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
