Where can i buy underbody braces?
Old Feb 16, 2007 | 09:09 AM
halfass872's Avatar
halfass872
Default Where can i buy underbody braces?
I was getting my Nismo Exhaust put on today, and apparently who ever owned my car before me must have bottomed out pretty hard and caught the cross brace under the car on something. It's the one directly below where the shifter goes up into the car.(Just before the resonator) they got it to clear the exhaust by using a bunce of washers to pull it down a bit from the car, but i wold like to eventually replace it. It's $200.00 for the part. I remember a while back seeing after market braces that go under the car, but i can't remember where i saw them. Any suggestions?? Thanks!
Old Feb 16, 2007 | 09:13 AM
Mike Wazowski's Avatar
Mike Wazowski
you mean the GT Spec and tanabe chassis braces?
Old Feb 16, 2007 | 09:19 AM
buzzardmountain's Avatar
buzzardmountain
Old Feb 16, 2007 | 09:40 AM
halfass872's Avatar
halfass872
Originally Posted by buzzardmountain
If that's what you're talking about, I got mine from Performance Nissan......they're suppose to be here the middle of next week.
www.mynismo.com
I just went there and didn't see either of those. I'm assuming i should be looking under the suspension catagory?
Old Feb 16, 2007 | 09:44 AM
ekim81's Avatar
ekim81
you can check the vendor FS forums... i think there were a couple of offers there.
Old Feb 16, 2007 | 09:46 AM
buzzardmountain
Old Feb 16, 2007 | 09:52 AM
MustGoFastR's Avatar
MustGoFastR
Be aware, though, that these braces were't designed to replace the stock "M" brace; they provide supplemental chassis rigidity in other areas. They also protrude further from the bottom of the car, and will scrape even easier.
Old Feb 16, 2007 | 10:42 AM
sentry65's Avatar
sentry65
the burninator
yeah you kinda gotta make the choice, lower the car more, or run a higher ride height with the braces
Old Feb 16, 2007 | 10:57 AM
halfass872's Avatar
halfass872
That sux. The factory one doesn't look like it does much, but i'm sure it;s there for a reason.
Old Feb 16, 2007 | 11:40 AM
Alberto's Avatar
Alberto
Cranky FI Owner
www.myspace.com/functiontuned tell Dave I sent you.
He sells products made by gtspec---> www.gtspec.com
I'll be doing underbody and suspension bracing soon
Old Feb 16, 2007 | 11:52 AM
Mike Wazowski
are you lowered? I am only down on Tein S techs and I have to take the Ladder bar off due to scraping. Just want people to know that even a slight drop + the ladder bad = scrape.
I am running both the bars in the rear though with no problem.
Once I get my new coil over set up and raise the car up a little more, I will put the GT Spec and Tanabe ladder supports on.
Old Feb 16, 2007 | 12:51 PM
sentry65's Avatar
sentry65
the burninator
the GT spec ladder and tanabe brace seem to make a big difference, but so does running the car lower...which you really can't do both
Old Feb 16, 2007 | 01:10 PM
halfass872's Avatar
halfass872
So out of this i'm getting that since it's my "M" brace that's bent, i can't compensate with an aftermarket brace. Correct??
Old Feb 16, 2007 | 05:31 PM
BamBam's Avatar
BamBam
GT-Spec is good stuff. I am putting it on mine now. Just keep in mind it will reduce your clearence by an inch.. I think it is more beneficial to handling then lowering the car (with the correct suspension of course).
Old Feb 16, 2007 | 05:56 PM
This is the brace near the shifter. There is another part that holds the OEM catalytic converters in place. I discarded that part a long time ago.
Old Feb 16, 2007 | 06:24 PM
halfass872's Avatar
halfass872
I'm at work so it wont show me the pic you put up But it's not the brace for the cats, its the "m" looking one from left to right under the car pretty much half way down the underside.
Old Feb 18, 2007 | 10:52 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
all the GT Spec braces are on our site here - both seperately, and as packages
http://www.z1auto.com/prodmore.asp?m...ing&prodid=937
any questions, let us know
Old Feb 18, 2007 | 05:24 PM
deisel's Avatar
deisel
gt spec stuff is not as good as tanabe 4 point. this piece was just released about two months ago. shoot me a message ill let you know the secret spot on a good deal. its a very nice set up. better engineering then gt spec
Old Feb 18, 2007 | 06:13 PM
SpoilsofWar's Avatar
SpoilsofWar
I would love to know what you're basing this statement on. The fact that the Tanabe hangs a full inch (at least) lower then it needs to when the GT spec scrapes as it is?
Old Feb 18, 2007 | 06:17 PM
sentry65's Avatar
sentry65
the burninator
i really don't think I'd say one is better than the other
I have both and think the GT spec brace's location does more to stiffen up the chasis than the tanabe brace. I actually didn't notice much difference with the tanabe added that the GT spec wasn't already doing
