Battery Problem?
Old Feb 16, 2007 | 11:48 PM
PANCHOVILLA's Avatar
PANCHOVILLA
Unhappy Battery Problem?
I recently purchased a OPTIMA yellow top.I was not aware that the post were different then stock.So I installed the Battery crossing the Neg.and Pos.It was hooked like this for about 5 Sec.now that this happened There is a Burning smell coming from the engine bay the battery is not hooked up like this as of right now.When I tried to hook up the old battery the same smell re-appears.What type of damage could I have done to my car, what should I do to see if there is any damage.It looks like I might be with out my car for awhile any help or info is greatly appreciated.
Thanks in advance
Old Feb 17, 2007 | 12:03 AM
zand02max's Avatar
zand02max
Does it still start and run properly?
Most Stereo Install places can extend the leads that way you can use the Yellow Top.
Old Feb 17, 2007 | 12:24 AM
PANCHOVILLA
I havent tried to start it do to the burning smell when I connect the battery.I orderd the right battery today just in case any one is interested in this OPTIMA batt. the model we need for our car is D35 this has the Pos. Terminal on the Right side instead of the Left.
Old Feb 17, 2007 | 09:08 AM
failsafe306's Avatar
failsafe306
Worst case is you fried your ECU and all of your sensors.
Old Feb 17, 2007 | 06:06 PM
PANCHOVILLA
Bump any more info?
Old Mar 23, 2007 | 10:28 PM
350ztoronto's Avatar
350ztoronto
i heard the red optima d35 is not the right battery someone told me it was red optimal reverse 34 can anyone confirm this?
Old Mar 24, 2007 | 07:44 AM
THE TECH's Avatar
THE TECH
What kind of more info do you want?? Check to see what works and what doesn't.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
