air/fuel help?
Old Feb 25, 2007 | 07:34 PM
myblack350z's Avatar
myblack350z
Exclamation air/fuel help?
Does anyone know how to install a air/fuel gauge? What is required to get it to work? it has 5 wire on the back 2 red, 2 black and 1 green,... were do wire the green one. do i conected to the o2 sensor or ECU .. to many wires in the o2 . ? any ideas
Old Feb 25, 2007 | 07:48 PM
Mike Wazowski's Avatar
Mike Wazowski
what brand? why dont you have the instructions?
Old Feb 25, 2007 | 08:03 PM
VoKaL's Avatar
VoKaL
ground, power, switch...those are what the wires are for.
dunno where each wire conects to but i do know that u connect to the o2 not ecu
Old Feb 25, 2007 | 08:26 PM
myblack350z
i know that the 2 red and 2 black connect to power and ground.. but what about the green.. i know it goes in the o2 sensor .. but what wire .. the o2 sensor has 4 wires... it has a black, gray, and 2 whites! what wire should i conected to ?
Old Feb 26, 2007 | 02:16 AM
therock2689's Avatar
therock2689
Gray. The two whites are the heater wires and the black is a ground. Gray is the signal you want.
Old Feb 26, 2007 | 06:07 AM
THE TECH's Avatar
THE TECH
I think he's talking about the POS Autometer gauge that doesn't do anything but have fancy flashing lights.
Old Feb 26, 2007 | 11:55 AM
myblack350z
ok guys.. i connected already. its a autometer gauge. i connect to the gray wire, but it only flash on lean. whats wrong with this ****! it won't go to rich or stoich...any more ideas?
Old Feb 26, 2007 | 12:14 PM
THE TECH's Avatar
THE TECH
It's cause you won't get any useful information from that gauge. It's good as a light show only. Buy a wideband.
Old Feb 26, 2007 | 01:44 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
alternatively, you can just get a cipher tool from AAM... I love mine and as long as you're N/A it's great for reading the factory widebands.
(make sure you have 2004.5 or newer car)
Old Feb 27, 2007 | 12:18 AM
rct350z's Avatar
rct350z
aem wideband !!!!!
Old Feb 27, 2007 | 04:52 PM
peptidbond's Avatar
peptidbond
Well, if you just want a gauge, get the PLX Devices PLX52BLK gauge. It can read a wideband signal and is much, much cheaper than the AEM standalone gauge. However, they have been discontinued. So, they are getting harder to find.
I have mine wired to my UTEC and tuner and it works great.
chachi999999999
Tuning
Aug 30, 2005 08:06 AM
Rogue350z
Jan 18, 2005 02:03 PM
MySunset350Z
Aug 14, 2004 02:46 PM
zland
Nov 3, 2003 07:22 PM
