Oil Filters?
Old Apr 8, 2003 | 03:08 AM
savage's Avatar
savage
Default Oil Filters?
Ok about to do my first oil change. was wondering what oil filters you guys are using. OEM Nissan part from dealer or aftermarket from auto parts store? If aftermarket a part number would be really helpful since those reference books in the store are never up to date. Thanks!
Old Apr 8, 2003 | 04:04 AM
Clyde's Avatar
Clyde
Default stock filter
I used Nissan's stock filters but got the one that's about 1" longer for more filtering. When removing the filter for the first time be aware that it has been tightened down with alot more torque than you're expecting. Damn near had to tear mine off to remove it.
Old Apr 8, 2003 | 05:47 AM
Zaphod 350z's Avatar
Zaphod 350z
Default Re: stock filter
Yeah, I needed channel locks to get mine off.
Old Apr 8, 2003 | 05:51 AM
Air's Avatar
Air
I think aftermarket oil filter is 4497 very small filter for 3.5 L.
Old Apr 8, 2003 | 06:50 AM
savage's Avatar
savage
Air,
What brand?
Old Apr 8, 2003 | 09:51 AM
jeffa55's Avatar
jeffa55
Try using the filter for a 2000 Maxima - I believe it is 7317 (Fram part number). I just put it on my 350 and it is about 2 times the size of the stock unit, but fits perfectly!
Old Apr 8, 2003 | 10:43 AM
2003z's Avatar
2003z
Whats the nissan part # for this?
Old Apr 8, 2003 | 10:58 AM
lEtMeZ1's Avatar
lEtMeZ1
If using a filter that is about twice as big wouldnt it be smart to add a little bit more oil??
Old Apr 8, 2003 | 10:59 AM
lEtMeZ1's Avatar
lEtMeZ1
Nevermind my previous thread. I guess more oil would be required than if using a smaller filter but all that would be needed is to look at the dipstick (Which if you change your oil you should!).... SOrry for the stupidity of my last post!
Old Apr 8, 2003 | 11:51 AM
Zaphod 350z
There are no stupid posts... only stupid people. hahaha. Just kidding.
Old Apr 8, 2003 | 12:02 PM
jeffa55's Avatar
jeffa55
Yes, I did add a little more oil. Basically, I added another .25 qts My honda's filter is about the same size as the 'larger' nissan filter and it calls for .5 qts less if you do not change the filter - since I am adding 1/2 the volume of the larger filter (the smaller filter is about 1/2 the size) then I figured an additional .25 qts sounded right.. and seems to be right on the dipstick!
Old Apr 8, 2003 | 12:43 PM
Air's Avatar
Air
Castrol or Mobil.
Old Apr 8, 2003 | 07:03 PM
lEtMeZ1's Avatar
lEtMeZ1
HAHA Funny Zaphod 350z
Old Apr 9, 2003 | 07:04 AM
ccondo's Avatar
ccondo
Default K & N
I am using the K&N oil filters.
Old Apr 9, 2003 | 07:12 AM
syf0n's Avatar
syf0n
I use the Fram filters and Mobil 1 SuperSyn 0W-40 -- the same oil I stick in the Boxster S, 911 Turbo, etc. I never see any problems with it. It seems like a blend of Mobil 1's "Fuel Economy" and "Performance" Oils to me
Anyone else have good experience with this stuff?
Old Apr 9, 2003 | 09:14 AM
Z'd's Avatar
Z'd
K&N HP1008- nice because you can use a 1" socket on the end to tighten/remove it.
AMSOil 5W-30
Old Apr 10, 2003 | 09:50 PM
mwaller's Avatar
mwaller
If you are set on using OEM filters, get the larger of the two (15208-9E000). I took both apart and was shocked to see how poorly constructed the smaller of the two is. In addition to being woefully small, the 15208-65F00 filter element is glued between carboard end-caps -- really crummy if you ask me. (For pics, see my post on the subject in the General forum) The best oil in the world won't do much good if the filter doesn't do its job. Even the very best full-flow car filters are poor at removing particles smaller than 20 microns. I haven't figured out why car maufacturers have not started to use high-efficiency bypass filters. Trucks have used these for years, and that's one of the reasons truck engines easily last for 1,000,000 miles.
Mika
Old Apr 11, 2003 | 12:06 PM
Russ's Avatar
Russ
Found this Oil Filter review link on another forum. It's somewhat old and he never got around to testing the K&N but still a pretty good read.
http://minimopar.net/oilfilters.html
http://minimopar.net/oilfilterstudy.html
The K&N HP-1008 wasn't in stock at the local auto parts store and it was going to take a week to get one, so I ended up using a Fram Tough Guard TG-6607 and Quaker State 5W30 for my first oil change.
I'm definitely disappointed with the cardboard endcaps mwaller found in the Nissan filter. Doesn't sound much better than the Fram Extra Guard.
Old Apr 11, 2003 | 06:51 PM
reen's Avatar
reen
Thumbs up Amsoil
I put in an Amsoil filter (SDF-13) when I switched to Amsoil 10W-30. From everything I read it is very high-end.
Very expensive though, for a filter. 13 bucks. However, the recommended service interval is several times that of regular filters, so I guess it evens out.
Old Apr 13, 2003 | 07:18 PM
stealthrapt0r's Avatar
stealthrapt0r
do any of u guys think the stp filter is good?
i read some reviews and it said it was about the same as mobil 1 and bosch, but it was alot cheaper, 3-4 dollars
