Oil Filters?
Old Apr 20, 2003 | 09:11 PM
SmokinZ's Avatar
SmokinZ
Default Oil Filters
Without a doubt, WIX makes the best filters!!
Any Fram filter is as big of a piece of crap as the OEM Nissan filter.
Go to NAPA and get a NAPA Gold oil filter...(made by Wix)
It's the best protection you can buy in an oil filter.
Mobil 1 is probably the best oil you can readily buy also...
However, I would not suggest using any of their 0w-30,40 products. Those are only for extreme situations!! (like living in Siberia).
The fellow on this forum using 0w-40 is doing a horrible dis-service to his cars...
$6 NAPA filter + $25 oil
Old Oct 10, 2003 | 08:09 PM
cheeves's Avatar
cheeves
Anybody know the thead size of the filter? Have read a couple of conflicting specs. Is it M20 x 1.5..or..3/4-16?
Old Oct 11, 2003 | 07:33 AM
lowrider's Avatar
lowrider
I like the K&N. I'm using the HP1006. The stock filter, and the K&N HP1008 are a little small. I called a K&N tech, and he told me the pressure specs on the HP1006 were the same as the HP1008. Used it on my last change, and it works great, It's about 3/4" longer and a wee bit larger OD.
Lou
Old Oct 12, 2003 | 02:38 PM
Resolute's Avatar
Resolute
The M1 and K&N are both made by Champion Labs, not the spark plug mker, and are excellent filters. Nissan OEM filters are not crap and are used by most of the SE-R cup racers, including Kojima. FYI, the SR20 and VQ35 take the same filter, and uses the same pump as the VE motor. M1 0W-40 is damn fine oil and is not for use in cold climates alone. That was an incredibly ingnorant post earlier. Check this site for all the info and more you can ever want on oil. The forums are gold and there is an analysis done on a VQ35 in there.
www.bobistheoilguy.com
Old Oct 12, 2003 | 03:09 PM
Da Gimp's Avatar
Da Gimp
I use K&N as well. Been using the 1008, but I think I will switch to the 1006 next time.
Old Oct 12, 2003 | 03:25 PM
MY350Z.COM's Avatar
Veruspeed filters!
Old Oct 12, 2003 | 05:19 PM
fairladyZ in Japan's Avatar
fairladyZ in Japan
Thank you, Victor.
Old Oct 12, 2003 | 06:18 PM
mytalon's Avatar
mytalon
I just stared useing the PureONE filter PL14610. It's about twice the size of the stock one.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
