Engine stumbling- will idle but not rev
Old Mar 9, 2007 | 07:48 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Default Engine stumbling- will idle but not rev
Well, I may have broke the record for first "issue". I've had my 2005 Enthusiast Z 6MT for two days and while sitting in very heavy traffic (going 0-2mph), it started to stumble when I revved it to move. It would idle fine, but as soon as I tried to rev, it would cough and sputter.
I nursed it to the side of the road and tried to work the gas pedal a bit to see if I could get it to rev. Nothing. It would idle fine and then just cough, sputter, backfire when I pressed on the gas and then the Service Engine Soon light came on.
I let it sit for about 10 minutes and it started and ran fine- but I did not get back into traffic.
The car has no Cats (resonated test pipes), so my guess is that is what's causing the problem.
I heard about fuel sending units being bad, and while I was low on gas (1/4 tank), I filled up right after it started up and I only put 14.8 gallons into it, so I don't think it was empty.
Any ideas..... kinda bummed right now.
Mike
PS- I can bring it into the dealer, but I'm thinking I should put the Cats back on before I do.
Old Mar 10, 2007 | 10:05 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Update #1:
Took the car to Autozone to use their code readers. The code was a:
P0335 Crankshaft Position Sensor A Circuit Malfunction.
On the way home, the TCS and Slip lights came on too. When it rains it pours.
Old Mar 10, 2007 | 10:16 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I am sure all the issues are related...get it to the dealer, they will take care of whatever the issue is
Old Mar 10, 2007 | 10:23 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Thanks, Z1.
The car is at a muffler shop getting the Cats put back on. I will take it to the dealer tonight if I can get there before they close.
Old Mar 11, 2007 | 05:26 AM
Armitage's Avatar
Armitage
Had something similar happen a couple of times, but my code was for a faulty voltage reading on my TPS sensor.
Take it to the dealer and let them work it.
Old Mar 11, 2007 | 08:08 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Appt at dealer for Tuesday AM.
Old Mar 15, 2007 | 09:55 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Update #2 (final?)
Dealer replaced the Crankshaft Position Sensor per the TSB and I'm back in business.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
