Car dies on startup!
Old Mar 23, 2007 | 11:37 PM
camthman's Avatar
camthman
Default Car dies on startup!
Hey guys just bought a 03 Z today and I pulled the KandN filter today and cleaned it.... oiled it up then put it back in. I then noticed that every time I would start it, it would start then the RPM's would drop and it would die. I cleaned the MAF and made sure everything was tight. If I give it alittle gas on startup, and hold the pedal down abit, then it will idle fine. Its only on startup this happens. I have searched and done the things they said and its hasn't worked sooo far. Any help guys?? -- Cameron
- Also im replacing plugs, changing oil, and doing other good stuff tomarrow. Thanks.
Old Mar 24, 2007 | 12:47 AM
camthman's Avatar
camthman
oh and i have also checked the 100 questions post and really didnt find what I was looking for...
Old Mar 24, 2007 | 02:33 PM
camthman's Avatar
camthman
no one knows??
Old Apr 26, 2007 | 05:09 AM
live2themaxuk's Avatar
live2themaxuk
Did ya find a fix?
Jamie
Old Apr 26, 2007 | 05:17 AM
Eazzy's Avatar
Eazzy
Clean ur MAF sensor
Old Apr 26, 2007 | 05:59 AM
drap660's Avatar
drap660
deff MAF sensor
Old Apr 26, 2007 | 09:25 AM
live2themaxuk
Well, ive cleaned my MAF and its still doing it. It all started for me, after a battery disconnection.. . . im assuming this dude did the same.. . .
Old Apr 27, 2007 | 04:55 PM
mgtibbetts's Avatar
mgtibbetts
your maf sensor is probably dead.
Old Apr 28, 2007 | 01:07 AM
live2themaxuk
FIXED: - CLEAN YOUR THROTTLE BODY
I took the intake pipe off the throttle body 'metal box that the large black intake pipe joins', disconnected the battery, sprayed carb cleaner into the throttle body, gently moved the buttefly valve up to give it all a real good clean and get all the black carbon deposits off, especially along the edge of the butterfly valve plate and all inside the chamber. Put it all back together, connected battery. Went for a drive, warmed her up. Starts EVERYTIME without fail as it should, and idle, without AC on isnt lumpy anymore, smooth as anything!! My idle speed isnt nessacarily 'higher' it just seems to be managing those low RPMS better. Im assuming the carbon deposits messed with the tolerances of the butterfly valve and intake flow
Can a moderator sticky this as i think this is a common problem that doesnt seem to have been addressed properly before, and the fact that it starts after a battery disconnection seems to lead people up the wrong path. Im sure the fact that it starts doing it IS ecu related, but my guess is that the carbon deposits build up over time, as does the ECU's compensation for the build up, then, when its disconnected, if forgets the compensation and thus the idle is AWFUL and it stalls on a warm start. . . . thats just my perception as to why it starts after a battery disconnection.
Jamie
Old Apr 28, 2007 | 04:26 AM
coreapoc's Avatar
coreapoc
Jamie
Deposits of whatever, unfortunately, if in the wrong spot will totally bog down an engine. If airflow is affected at all youll have problems.
Old Apr 28, 2007 | 07:17 AM
Eazzy's Avatar
Eazzy
If your butterfly is hung up from closing completely, you will in essence have a vacuum leak. Thats a good call, but if I recall, due to the elec. throttle control, you have to use caution in manually opening the throttle plate and it is best to remove the TB and spray from the base to the inlet.
Old Apr 28, 2007 | 09:22 AM
Cube's Avatar
Cube
Yep, you're right. Not supposed to touch the valve since it's an electronic (hence drive-by-wire) TB. Has your idle raised at all since doing this? You may have thrown the position off from it's original resting (idle) spot.
Old Apr 28, 2007 | 10:31 AM
live2themaxuk
no its absolutely fine. Honestly i have had no problems, and quite a few ppl have done this. I dont know why it would be a problem as long as the battery is disconnected. There are a number of procedure that you can do to re-calibrate the throttle positioning anyway.
etkms
Jun 19, 2022 06:30 PM
Mattg350z
Oct 2, 2015 06:51 AM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
