Bleeding coolant?
Old Mar 24, 2007 | 10:47 AM
Kiamo's Avatar
Kiamo
Question Bleeding coolant?
I have a bit of air in my coolant system and was wondering how to get it out on the Z.
Thanks for any assistance!
Old Mar 24, 2007 | 11:34 AM
rblimas's Avatar
rblimas
first thing your going to need to find out how the air got in there.
patch up the hole or what every needs to be patched.
then you going to need to get a coolant flush of something like that(dont put that in stone)
Old Mar 24, 2007 | 11:38 AM
halfass872's Avatar
halfass872
If it's just a little air, it'll work it's way out through the overflow tank. If it's alot you can open the vent valve on the rear passenger side of your engine. It's inline with coolent hose. just open it a little while running, after it's up to temp, and bleed untill you get coolent out of it and no air.
Old Mar 24, 2007 | 11:42 AM
rblimas's Avatar
rblimas
and that is why i said "dont put that in stone"
Old Mar 24, 2007 | 12:28 PM
Kiamo's Avatar
Kiamo
Dang, back of the engine sounds hard to get to.
Its not a lot of air, we had to take the front fat coolant hose off, so its about as much as fits in there.
Old Mar 24, 2007 | 02:04 PM
simstad's Avatar
simstad
There is a coolant bleeder just right of the battery cover, between the intake plenum and the battery cover. It has a green cap on it. Just remove the cap and use a screwdriver to bleed the air in the coolant, have a rag handy to prevent leaking on the valve covers or manifold. Keep the coolant overflow tank full to prevent additional air pockets.
Courtesy Nissan used to have the pdf of the service manual online if you need it to get the bleeding/filling details.
If you can't find it, I can probably email you the pages with the coolant bleeding instructions. Send email address if you need it, but try the search function on this site first.
Old Mar 24, 2007 | 02:10 PM
halfass872's Avatar
halfass872
I had to leave my desk while i was typing my post, so you beat me to it. Relax, didn't mean to step on you pee-pee
Chris350z03
Oct 8, 2023 07:19 PM
lapham3
Oct 7, 2022 03:15 PM
SharX59
Sep 27, 2015 09:23 AM
smithmt3
Sep 11, 2015 08:25 PM
