VQ35HR combustion chamber volume...anyone know it?
Old Mar 26, 2007 | 07:07 PM
nismology1's Avatar
nismology1
Default VQ35HR combustion chamber volume...anyone know it?
Has anyone cc'd the HR heads yet? If you have, post here.
TIA.
Old Mar 26, 2007 | 07:49 PM
rednezz's Avatar
rednezz
I saw a pic of the VQ35HR heads and they looked very almost identical to the Cosworth heads...if they are the same then the CC's would be 58.
Old Mar 27, 2007 | 10:24 AM
nismology1's Avatar
nismology1
Well i think if anything the HR heads would have a smaller volume or same as OEM DE heads due to the squish pads. I really need to know this...
Old Mar 27, 2007 | 10:31 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Its easy...
3.5 liters
10.6 compression ratio
6 cylinders
= 55.03 CC @ TDC/cylinder
Is this what you were looking for?
Old Mar 28, 2007 | 07:12 AM
nismology1's Avatar
nismology1
Originally Posted by Hydrazine
Its easy...
3.5 liters
6 cylinders
Is it really that simple?
Thanks for that. The only issue with this though is that it doesn't tell me if the decreased combustion chamber volume is by virtue of a smaller combustion chamber or increased piston dome. I need to know since I'm thinking of sticking HR pistons in my block. It's already apart and needs to be machined anyway to accept oversize pistons so i thought these would be a cheap mini-upgrade. I need to know what the resulting compression ratio with the HR pistons and DE heads will be before i move forward.
Old Mar 28, 2007 | 04:05 PM
Hydrazine's Avatar
Hydrazine
That I couldn't tell you.
Only way to know is to try it.
Old Mar 28, 2007 | 04:12 PM
bofa's Avatar
bofa
^So Tony... what's up your sleeve for the HR?
Old Mar 28, 2007 | 04:16 PM
nismology1's Avatar
nismology1
See nothing wrong with threadjacks, huh?
Old Mar 28, 2007 | 04:17 PM
nismology1's Avatar
nismology1
Just slapping them in is the last thing i want to do. Thanks anyway.
Old Mar 30, 2007 | 07:35 PM
bofa's Avatar
bofa
Not at all, esp since you got your answer.
Old Mar 30, 2007 | 08:00 PM
nismology1's Avatar
nismology1
I got helpful answer (which i thanked him for), but not specifically what i was looking for. Looking for head cc's in particular.
350Z Project X
Oct 17, 2015 05:16 PM
_koubie_
Sep 20, 2015 06:34 PM
