TB coolant lines
Old Apr 7, 2007 | 02:16 AM
TayTaythatsme04's Avatar
TayTaythatsme04
Default TB coolant lines
Is there any benefit to having the coolant lines by-pass the TB ? I otice mine are like that after I swapped plenums.
Thanks
T
Old Apr 7, 2007 | 02:46 AM
halfass872's Avatar
halfass872
Curious as well.
Old Apr 7, 2007 | 06:20 AM
Q45tech's Avatar
Q45tech
One of the purposes of heating TB and plate is to avoid PCV and EGR vapors from condensing on the rear and bottom of throttle plate.
At WOT the air is moving so fast thru TB and plenum that there is no time for it to heat up to coolant temperature...............at idle and cruise the few degrees of heating is a good thing.
Measure the temperature inside plenum of air flow not the external housing metal.
Old Apr 7, 2007 | 07:25 AM
MustGoFastR's Avatar
MustGoFastR
Benefit is no hot coolant running through your plenum neck; cooler plenum temps.
Old Apr 7, 2007 | 08:12 AM
TayTaythatsme04
so I should just leave it then
T
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
SharX59
Sep 27, 2015 09:23 AM
