Engine oil level
Old Apr 10, 2007 | 01:25 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default Engine oil level
I just had an oil change, i checked the level this morning its a little over than it should
(low) L XXXXXXXX H (high)
mine is on the 7th X, is that over filled??? I used 5 qts. of Mobil 5000
Old Apr 10, 2007 | 01:26 PM
Kevins350z's Avatar
Kevins350z
that indicates low. doesnt it?
Old Apr 10, 2007 | 01:31 PM
halfass872's Avatar
halfass872
L XXXXXXXX H
That's exactly where it should be. Same spot mine is every time i change mine. Manual states anywhere between L and H is fine.
Old Apr 10, 2007 | 05:08 PM
Bevo's Avatar
Bevo
You are good, nothing to worry about
Old Apr 10, 2007 | 05:12 PM
Mid117's Avatar
Mid117
So as long as its between the L and H, it's good?
How do you guys check if the motor is eating oil? Below the L line? (rev-up 6mt)
Old Apr 11, 2007 | 03:39 PM
Tim@WestCovinaNissan's Avatar
Drive it for about 1000 miles after the oil change if it is registering below the "L"...take it to a dealer to start a consumption test.
Old Apr 11, 2007 | 04:20 PM
Mid117's Avatar
Mid117
Cool, thanks a lot. Gonna keep an eye on it from now on.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Fixxxercask
Nov 9, 2015 11:10 AM
