i am a noob :]
Old Apr 15, 2007 | 11:12 PM
xtasy127's Avatar
xtasy127
Default i am a noob :]
350z is my first manual car... and ive always had these questions in mind...
this car has a weird transmission, correct?
-the clutch vibrates when you rev high
-the catch point is very different from normal cars
-transmission noise is normal (from research on this forum)
-whining noise when downshifting is normal (also from reseearch)
not sure, gimme some feedback
Old Apr 15, 2007 | 11:38 PM
kourosH's Avatar
kourosH
if this is ur first manual car...how can u kno the catch point is different then other cars?
Old Apr 15, 2007 | 11:39 PM
xtasy127's Avatar
xtasy127
oh cause ive driven other manual cars :O
Old Apr 16, 2007 | 04:39 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Normal?... That depends...
It is also somewhat normal for our transmissions to be defective too... but being defective shouldn't be normal.
Bring your car to someone qualified to check it out (not the dealer). They can tell you if you have a real problem or not.
Old Apr 16, 2007 | 04:44 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
each car has its own engagement point to the clutch - the Z can be considered to have one higher than most cars, but lower than others.
There should be absolutely no vibration, at any rpm (at least mine doesn't, and its well used at this point)
Noise - at idle the throw out bearings can be a tad noisy - a slight noise is considered acceptable, a loud racket is a bad throw out bearing in most instances
Old Apr 16, 2007 | 03:41 PM
xtasy127's Avatar
xtasy127
hmm like pretend im reving to 7k like when im about to shift the clutch pedal feels shaky or like vibrating when i put it into the next gear
Grottizy
Mar 30, 2005 09:15 PM
curnaco
Mar 5, 2005 06:06 AM
zupernoc
Feb 23, 2004 10:56 AM
SupermanSS
Nov 1, 2002 09:37 AM
