Need Help ASAP *Quick question about drive belts*
Old Apr 21, 2007 | 03:47 PM
Frostydc4's Avatar
Frostydc4
Default Need Help ASAP *Quick question about drive belts*
I was driving home and I noticed that one of the drive belts was shredded (see pics below). First question, what accessories do these belts drive (A/C?) and would I be able to drive to the dealer to change it (or should I tow it)? Thanks.
Attached Thumbnails Need Help ASAP *Quick question about drive belts*-picture-001.jpg   Need Help ASAP *Quick question about drive belts*-picture-002.jpg   Need Help ASAP *Quick question about drive belts*-picture-003.jpg   Need Help ASAP *Quick question about drive belts*-picture-004.jpg
Old Apr 21, 2007 | 03:54 PM
hwcustoms's Avatar
hwcustoms
Just loosen 12mm bolt in the middle of the idle pulley. Then loosen the 10mm tensioner under the car. You can get the belt at any auto store. The belt that goes on the back of the crank pulley has 4 ribs and the one in front has 6. Just tell them which one you need. It looks like you broke the one that controls the water pump pulley so I would not drive it. Just change it yourself and save the money. This is a 20 dollar fix.
Old Apr 21, 2007 | 03:55 PM
hwcustoms's Avatar
hwcustoms
Also the belt on the left of the motor controls the altenator and the power steering pump. The one on the right controls the water pump.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
