Does your clutch ever stick to the floor?
Old Apr 22, 2007 | 07:53 AM
coachk's Avatar
coachk
Originally Posted by flintgauge
yes, mine does sometimes. I just get out, pop the hood and cuss out my master cylinder then it works fine for a while.
LMAO....Cheap and Affective...Might want to kick the tire too...
If your going to drag race occassionally its definitely time for a better clutch and flywheel.
Old Apr 22, 2007 | 09:53 AM
carlos067's Avatar
carlos067
Originally Posted by Diesel350
LOL, Were you at Brandon race way today too?
nope just here in Gainesville
Old Apr 22, 2007 | 07:31 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
deisel, let me know if you need a clutch installed. i will take care of ya !!
Old Apr 23, 2007 | 05:55 AM
Diesel350's Avatar
Diesel350
Ya I'm going to start looking for a clutch. Do you have any recommendations? I want to stay NA. Also I really don't want to replace my flywheel unless I have to. I'm not really looking to get a lightflywheel due to the noise.
Old Apr 25, 2007 | 07:12 PM
carlos067's Avatar
carlos067
$#IT happened to me at the track today!!!! thats twice now after the most beautiful launch ever!
Old Apr 25, 2007 | 07:45 PM
Diesel350's Avatar
Diesel350
Damn that sucks, Time to upgrade to an SS clutch line with High temp Fluid.
Old Apr 26, 2007 | 05:20 AM
clipso 01's Avatar
clipso 01
mine does sometimes....i think it gets caught on my floormats
Old Apr 26, 2007 | 10:44 AM
RebelinRI's Avatar
RebelinRI
Put it in neutral when it sticks and give it a good couple of revs (5k+). If it comes back then your pressure plate is probably sticking. Nissan seems to have a problem with the master and slave cylinders. You can have a look at that too. Hope it helps.
Old Apr 26, 2007 | 11:19 AM
jamnew's Avatar
jamnew
It happened to me once at 11500 while feathering on a steep hill in heavy traffic. Scared the hel# out of me, but it hasn't happened since. The clutch smell on the way home was the worse!
Old Apr 26, 2007 | 11:30 AM
Dio1988's Avatar
Dio1988
happened to me 2 days ago for the first time after reading this thread. i think this thread is cursed
Old Apr 26, 2007 | 01:04 PM
Diesel350's Avatar
Diesel350
Just ordered an SS clutch line and high temp fluid. I will report back then to see if I still have clutch stick after install.
Old Apr 26, 2007 | 01:11 PM
carlos067's Avatar
carlos067
SS clutch line FTW that will prob be my next mod after the exhaust
Old May 5, 2007 | 03:11 PM
msu10s's Avatar
msu10s
ya just bought a 2007 Z in March and the dealership already had to replace the entire clutch because it kept sticking to the floor and they couldn't figure out why.
Old May 6, 2007 | 05:20 PM
Nerek's Avatar
Nerek
Once they replace it does it stop the clutch from sticking?
I've had numerous times where i would take off hard or even go into 2nd and the clutch would just stick to the floor.Happened the other day while it was warm outside too.
Old May 7, 2007 | 11:04 PM
dmoffitt's Avatar
dmoffitt
Originally Posted by marine_playboi
My 07 with only 6k on it does that everyone once in a while, when the weather changes from hot to cold or cold to hot, not sure why, dealership was baffled, how bout that ****....
clutch fluid, like brake fluid, is hydroscopic. that means it absorbs moisture - perhaps the change in temps caused condensation causing an issue in the line because of said moisture?
Old May 7, 2007 | 11:06 PM
Devil Z's Avatar
Devil Z
I've had this happen to me ONCE in California.
Old May 8, 2007 | 03:32 AM
jonnylaw's Avatar
jonnylaw
for real--it is worth getting a ss line and motul rbf600 flush before replacing other clutch parts--b/c its really an inexpensive mod and I have not experienced any sticking issues since I did this (and it happened to me a lot before)--IMO the main cluprit is the clutch fluid cuz I think it has a tendecy to boil when you run these cars hot--which the engine bay area already running hot to begin with, and when you start adding headers and hfc's to the mix, things get really hot and in addition to the boiling clutch fluid, the rubber stock clutch line has a tendancy to expand so the ss line and high temp fluid are really worth a try if you haven't already done so, and it solved my headache on the issue. Just my .02
Old May 17, 2007 | 11:30 AM
  #38
UberJonny's Avatar
UberJonny
This has happened to me a few times with my '04. Just about any time I feather the clutch from 1st to 2nd with the engine reving above 4000 RPM, the clutch either sticks or doesn't engage as crisply as it normally does and there's a distinct buring smell. However, when I bought the car, the dealership told me that the previous owner had purchased a NISMO clutch disc. I wonder if that might have something to do with it.
Old May 17, 2007 | 07:32 PM
  #39
Diesel350's Avatar
Diesel350
I've had the SS clutch line and the Motul High Temp fluid installed for 2 weeks now and have done back to back to back very hard 3k launches feathering the clutch and no sticking of clutch so far.
Old May 17, 2007 | 10:17 PM
  #40
Sponge's Avatar
Sponge
I'm having the same issue after some driving when it is 90°F+ here in CA. Having headers, HFC, popcharger, intake manifold, I think it's getting hot in the engine bay. Where did you get the ss clutch line and high temp fluid? How much were both items? Summer is coming and I hate this crap so want to fix this now.
Thanks
