Intake, MREV2, Spacer & More... no perf
Old Apr 27, 2007 | 09:52 AM
Chebosto's Avatar
Chebosto
double check for leaks?
might think about reflash for AFR corrections and timing with other driveability improvements (throttle response), but its not gonna solve phyiscal hardware install issues.
Old Apr 27, 2007 | 02:12 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by pcressey
Really? Directly off www.motordyneengineering.com:
"This stealth modification adds 11HP-13HP and reduces the effect of power robbing heat soak. The 5/16" plenum spacer is fully compatible with all stock and aftermarket strut bars."
"Multiple independent test show when used with a 5/16" spacer on the REVUP engine, the combination will add a "minimum" of 15+ HP and 18+ TQ in the upper midrange. Many independent MREV 2 Manifold REVUP tests have dynod in excess of 20HP and 30 TQ in the upper midrange and with high RPM peak power increased by 3-5 HP."
The car does feel more responsive and better, but the actually HP is not there. I am taking it to the SoCal Dyno Day in May... so I will see the actually RWHP.
an "after" dyno is not useful without a "before" dyno.
I have been present for several "before" AND "after" dyno tests of the MREV2 and spacer combinations, and the products work as advertized. If you're not happy, again, just return them.
Old Apr 27, 2007 | 04:51 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
+1 to what Wired24/7 said.
Im sure that no matter how it compared to your friends dyno, there was a definite gain of at least 15HP in the upper midrange of your Z.
If your dyno didn't do much different than your friends, there is also the variable of the ECU moving the performance settings (timing) up or down. It happens all the time.
When doing a dyno I always suggest doing a ECU reset. Sometimes it can make a significant difference in your results depending on where your ECU was starting from. It seems there is about a 5-15 HP variability in power output depending on what mood your ECU is in. I've seen it on the dyno many times.
A ECU reset always puts your car back into performance mode.
Coolant and air inlet temperature can also make a big difference so it is important to carefully control these variables before and after installation of a mod that is to be tested on the dyno.
Doing the controls will help you focus on what mod does and not the ECU.
Tony
Old Apr 28, 2007 | 06:28 AM
Q45tech's Avatar
Q45tech
Changing the air path in front of MAF may create problems as the oem MAF equation [translation of MAF voltage to grams per second] was created to track oem filter box and intake.
On some cars/brands the MAF voltage drops [with CAI] which fools the ecu into leaning the mixture a few % which can increase power at some rpms on some cars the opposite occurs.
At WOT and 6,000 rpm even 0.01 volts [4.41 volts] difference is material.
Every 11F =1%; every 333 feet =1%
Engine is rated at 77F intake air at IAT roughly 60F ambient in shade with sufficient air flow to neutralize radiant engine heat.
Old Apr 28, 2007 | 06:56 AM
ke0ki2k's Avatar
ke0ki2k
Thanks for the replies... I should clarify just a bit.
The only time I ran the car at high elevation was for the 1/4 mile runs. The 1/8 mile was pretty close to sea level, and when I race my friend we are on the coast.
I would think with the UO Crank Pulley and the Intake Manifold alone I should at least walk a bit on my buddies stock '03.
I guess you have to drop close to $8k on forced induction to gain that valuable second or two.
mightve got a better jump, might shift faster than you? something. is yours a revup with the mrev2/spacer? if so you'll have more midrange and more topend than him, oughta walk him.
Old Apr 28, 2007 | 06:59 AM
ke0ki2k's Avatar
ke0ki2k
of course, a lighter flywheel and lighter wheels/tires or a 3.9 final drive setup would have you walking your bud everytime. Eliminating rotating mass will do more for acceleration than anything else N/A. Plus an 06' GT is gonna weigh alot more than an 03' Track. lightweight battery, test pipes, lighter wheels, toss the spare & jack, and you'll lose 125 pounds or so. even things up a bit.
Old Apr 28, 2007 | 10:36 PM
terrasmak's Avatar
Even if you gained 20+ hp , it wont always make you faster. 20 extra hp can do weird things to a chassis when its not set up for it, same thing for the driver.
Old Apr 29, 2007 | 07:39 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
From my understanding, CAI's do not do very well with spacers. Go 06 airbox and drop in, popcharger, or just short ram your injen.
Old Apr 29, 2007 | 09:24 AM
pcressey's Avatar
pcressey
I am definitely not going to remove the MREV2 and spacer... as I said, the car does feel better than it did stock.
I will convert my Injen to a shorty and go from there.
Old Apr 29, 2007 | 10:29 AM
2 low Z's Avatar
2 low Z
It was menchioned before. Lighten the load, you have a Touring and he has as Track model. Stock for stock, he already had an advantage because of weight.
Old Apr 29, 2007 | 12:53 PM
Hydrazine's Avatar
Hydrazine
If you have a stock air box, that would be a better option.
A short ram intake in the engine compartment (without a heat shield) will suck in a lot of very hot air from behind the radiator.
And hot air will clearly reduce power.
Go stock box!
Old Apr 29, 2007 | 12:59 PM
RBlover69's Avatar
RBlover69
im still waiting to see someone with the damn 1/2 spacer there has to be someone in the world with a damn 1/2 spacer. BAH with this 5/16 i wanna see a real spacer ...come out where ever u are man. Peak hp people where are u. !!!!!!!
Old Apr 29, 2007 | 01:33 PM
Hydrazine's Avatar
Hydrazine
I already did that test a long time ago.
1-2 more HP above 6K and about 1-2 less HP everywhere else below that.
Overall the 1/2" spacer makes less area under the curve. It will make more power for a race application, but would mean ditching the strut bar for it.
For a 1/4 mile race or street application this would be fine, but for road course racing, I would keep the strut bar.
Old Apr 29, 2007 | 02:14 PM
RBlover69's Avatar
RBlover69
cool tanks brotha
Old Apr 29, 2007 | 07:42 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
stock air box with motordyne spacer is the best combo!!
dont try to justify the money you spent on the injen by making it a short ram. that doesnt help either. good luck and post some more times up!
Old Apr 29, 2007 | 08:22 PM
skaterbasist's Avatar
skaterbasist
Go stock box!
The Stillen Airbox seems to have an even better form than the stock airbox. It has a very good heat shield and its a short ram.
From your knowledge, lets say in his situation, would using a Stillen Airbox benefit him?
(Not sure if im asking the question in a manner which you could understand)
Thanks for any help!
PS. I have a 5/16 spacer & Mrev2 on my list, with Stillen CAI already installed.
Old Apr 29, 2007 | 08:30 PM
Devil Z's Avatar
Devil Z
Stock Airbox > Popcharger
Old Apr 29, 2007 | 08:33 PM
  #38
Audible Mayhem
My350z
yup
Old Apr 29, 2007 | 08:35 PM
  #39
Hydrazine's Avatar
Hydrazine
The Stillen flows a little better than stock and has the best heat shield of all the after market intakes but the stock still runs cooler.
Old Apr 29, 2007 | 08:37 PM
  #40
michael22force's Avatar
michael22force
well.... i have a stock o6 z with a cai my buddy has an 06 g35. stock it wasnt even a race. then he got a 5/8 spacer and headers still not a race. then he got full exhaust and off the line not a race but from a 40 to 60 punch we are about dead even. so i think that the spacer does help but exhaust seems very important.
