Help.oil fouled.
Old Apr 28, 2007 | 02:19 PM
04z350's Avatar
04z350
Unhappy Help.oil fouled.
Hey guys i just decided to change out my spark plugs because my car has not felt so powerful as it used to. All of the plugs are oil fouled, and I can see oil residue coming from under the intake manifold, any information would be great, help!
Jeremy
Old Apr 28, 2007 | 02:23 PM
Sean's Avatar
Sean
mods? mileage?
Old Apr 28, 2007 | 02:40 PM
04z350's Avatar
04z350
headers, kinetix intake manifold, and intake, 48,542 miles
Old Apr 28, 2007 | 02:42 PM
Sean's Avatar
Sean
any access to a compression tester?
Old Apr 28, 2007 | 02:45 PM
04z350's Avatar
04z350
Unfortunately no. Bought the plugs on friday because I just wanted to do some normal maintenance today now im worrying.
Old Apr 28, 2007 | 02:50 PM
Sean's Avatar
Sean
I am worried it's your rings, need to test to find out.
how low is your oil?
Old Apr 28, 2007 | 02:53 PM
04z350's Avatar
04z350
I just changed it recently 5 quarts. I can never tell with the stupid dip stick we have, it always picks oil off of the dipstick tube
Old Apr 28, 2007 | 02:55 PM
Sean's Avatar
Sean
did you put the plugs back in? I think checking to see how fast they foul will give you an idea of how bad it is....but you must get a compression test.
Old Apr 28, 2007 | 02:57 PM
Sean's Avatar
Sean
any chance you overserviced the oil? drive near red line often? went a while with low oil (more than a qt. low)
Old Apr 28, 2007 | 03:03 PM
04z350's Avatar
04z350
Well I don't believe I overserviced it, though I do drive spirited sometimes. I guess I will just change the plugs and check them next weekend, appreciate the help though really, thanks.
Old Apr 28, 2007 | 03:13 PM
Sean's Avatar
Sean
get a compression tester. good luck
Old May 3, 2007 | 10:23 PM
denchan350gt's Avatar
denchan350gt
Can you do a compression check yourself or do you have to take it to a shop to do it?
How easy is it to do and what is needed or have to be disconnected from the engine for the tester to work?
Old May 3, 2007 | 10:27 PM
Sean's Avatar
Sean
you can do it, the tester replaces a spark plug (one at a time). you dissconnect the spark for the engine. just using the starter motor to turn the engine over will give you the reading.
Old May 4, 2007 | 04:48 AM
SpeedRcr's Avatar
SpeedRcr
i had some blow by at 30k miles on the 2 back plugs...but it was normal, we pulled 2 other cars and they had the same signs...
Old May 4, 2007 | 05:06 AM
blasian's Avatar
blasian
Could be tube seals are leaking too. I had a few plugs with some oil on them.
Old May 4, 2007 | 08:07 AM
VO...'s Avatar
VO...
Administrator
that's what I was thinking too.
Glex25
Oct 11, 2012 08:11 PM
636Racer
Feb 1, 2012 12:34 PM
EugeneC7152
Dec 26, 2011 07:40 AM
