1st Dyno... *tears*
Old May 4, 2007 | 04:55 PM
drewk's Avatar
drewk
Default 1st Dyno... *tears*
I have an 05 enthusiast 6spd. Mods are Motordyne 5/16 copper isothermal spacer, JWT popcharger and invidia N1 catback exhaust. Do these numbers sound right? I have seen stock numbers higher than that. All pulls were done on third gear. And it was on a dyno jet. I am kind of dissapointed with the numbers , I was wondering if anyone could help.Sorry if the dyno sheet is too small, but
MAX Power =236.92
MAX Torque= 222.01
Old May 4, 2007 | 05:03 PM
michaeljr6's Avatar
michaeljr6
some ppl stock dyno is higher than that.........z's are slow
Cannysage's Avatar
Cannysage
that's super low.
Old May 4, 2007 | 05:13 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Answer me these questions and I'll tell you if you should cry:
1. Did you get a "before" dyno?
2. Have you seen stock numbers higher than that from the same dyno you used?
3. Do you know if that air/fuel ratio is accurate? If it is, you have a lot of untapped power to be gained by tuning. You are generally running leaner than you should to make optimal power.
Comparing numbers from one dyno to another is like two virgins comparing sexual positions. It's pointless, bullsh1t, inaccurate, and they are only comparing based on stuff they've seen or read.
If you answered "no" to either question 1 or 2, then you have nothing to cry about. Different dynos have different calibration and correction factors. So if one dyno says 230whp another one can easily read 260whp.
Old May 4, 2007 | 05:15 PM
sentry65's Avatar
sentry65
the burninator
do you have a baseline? what do stock Z's dyno on that particular dyno???
no reason to feel disapointed until you have something to compare your car to other than other cars online all around the world
Old May 4, 2007 | 05:16 PM
gabez33's Avatar
gabez33
I heard somewhere on these forums that you have to do a 5th gear pull on the 287, for the best HP measure...I maaay be wrong though
Old May 4, 2007 | 05:19 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
no, it depends on the dyno, the operator, and the calibration etc
Old May 4, 2007 | 05:30 PM
jondimellow's Avatar
jondimellow
too bad u dont have vtech....
but don't be fazed man, dynos aren't meant for just looking at the numbers, they should be used as comparison, so baselines are super important.
Old May 4, 2007 | 08:18 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
On an inertia dyno, it would have been best to use 5th gear, or 4th at the least. Probably a few whp missing since you used 3rd. I wouldnt read too much into this one dyno session. Go back and make some pulls in 4th/5th gear and see what happens.
Old May 4, 2007 | 08:19 PM
VN_350z's Avatar
VN_350z
RSX number is higher
Old May 4, 2007 | 09:00 PM
drewk's Avatar
drewk
Default Wired 24/7
1) No
2) Yes
3)dunno
I just needed some help, maybe someone could lead me in the right direction. What should I do next, maybe a tune would help?
Oh and I'm not really crying, u silly goose....
just a little dissapointed that's all.
Old May 5, 2007 | 12:48 AM
gsazabi's Avatar
gsazabi
+1
3rd gear dyno might have contributed a bit to low dyno#'s.
My dynojet baseline dyno numer was 240whp/232tq FYI.
Old May 5, 2007 | 01:04 AM
+1. Dynamometers are great diagnostic and tuning tools. If you find another dyno that gives you bigger numbers, you will have the same horsepower. Just bigger numbers.
Old May 5, 2007 | 01:23 AM
chriskabobbers's Avatar
chriskabobbers
i don't get why some of our dyno numbers look so low on paper =( it just disappoints me. for a "350"z, 230 whp just sounds too low.
Old May 5, 2007 | 04:10 AM
StaticCling's Avatar
StaticCling
Sorry, but I have only used GRD and CJ Motorsports for dyno's. I would post this on chicagoz.com as I am sure people there have gone to speed quest
Old May 5, 2007 | 04:26 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
very true. most cars put down the best numbers in 5th gear on a dynojet.
third is way too low of a gear.
Old May 5, 2007 | 08:41 AM
gsazabi's Avatar
gsazabi
The name "350z" is derived from the engine displacement.(I wish it stands for amount of hp)
Old May 5, 2007 | 10:51 AM
LG_z33's Avatar
LG_z33
Aye, best to use the 1:1 ratio gear on whatever car you dyno.
Old May 5, 2007 | 10:53 AM
Alberto's Avatar
Alberto
Cranky FI Owner
+1 My car has always Dyno'd way lower in 4th gear over 5th on DJ's. Take this as a lesson to always dyno in the 1:1 gear, you paid for an incorrect dyno-due to lack of knowledge. Dont let shops pursuade you to use 4th cuz 5th goes to high mph wise, they can spin to 200mph IIRC, always dyno in 5th!
Old May 5, 2007 | 10:55 AM
Abishop's Avatar
Abishop
I dyno low also, dyno numbers vary on any given day. dont worry.
