what would be the problem
Old May 6, 2007 | 02:44 PM
nightcrawler_8's Avatar
nightcrawler_8
Default what would be the problem
am sorry if am bringing any old topic.. but i dont really know whats the problem and it tried to sdearch but i couldnt find something close to what am facing
i dont really know if what am facing is a problem or just me not shifting the write way
the problem is when i drive normally (cruising) everything is fine and shift soo fine with no problems...
but today i was with my freind and he just baught new VW golf GTI and he wanted to know how storng is his car, so we decided to have a freindly race.. so we started and it was the first time push my car really far .. so i noticed the following: i started in 2nd gear .. and when the rev hits 6100- 6300 i pressed the clutch and 3rd and once i released the clutch i heard souind from the rear (buug) ,.,, also form 3rd to 4th the same and 4th to 5th.. and after we stoped there was a wiered smell
is that a problem or its just me not synchronizing my shifting and removing the clutch at the right time..
i would really aprreciate your help.. my warranty will be expired after 10 days.. so if there is a problem i should get it fixed before they charge me hell of money..
thanks again and sorry for the long explanation
sorry for reposting in this section . but i guess no much ppl checking the repairing section and i need some ideas urgently as my warranty will be over in 10 days..
Old May 6, 2007 | 10:24 PM
nightcrawler_8
bump bump /./..
Old May 6, 2007 | 10:32 PM
redman333's Avatar
redman333
If you only have 10 days why don't you just take it in and say you hear a wierd noice. The worst they can do is say there is nothing wrong. If your lucky, you'll get something replaced for free.
Old May 7, 2007 | 12:44 AM
nightcrawler_8
thats why am asking you guys.. cause if they ssay nothing is worng i will have something to say cause i will know that they are just trying to run away with it,,,
comn pros ..
Old May 7, 2007 | 07:56 AM
nightcrawler_8
dont dissapoint me guys .. i am stuck and need help :
Old May 7, 2007 | 08:18 AM
andypandy's Avatar
andypandy
what does the noise sound like? try driving normally and see if the noise reproduces. is the smell coming from the clutch?
also, not familiar with the z's (i have a g), but was the car's VDC/TCS whatever the hell it is off when you dropped the clutch?
Old May 7, 2007 | 08:23 AM
nightcrawler_8
thanks for at least replying.
VDC is OFF
when driving normally there is no sound at all. only when shifting hard.
my buddy thinks its differntial.. i dont really .. am soo confused.
the smell i can feel it in the cabin . i guess yes its the clutch smell.
the sound is like .. duuuuug .. really just as am saying . once i let the clutch go i hear duuuuuug.. from the rear.. just as if rims was not connected and suddenly get connect..
Old May 7, 2007 | 08:25 AM
andypandy's Avatar
andypandy
more than likely if the sound is coming from the rear, could be anything from the rear portion of the drivetrain. perhaps it's the differential? not exactly sure...
the best thing you can do now is take it to the nissan dealer and reproduce the problem. hopefully it'll be fixed in no time.
good luck.
Old May 7, 2007 | 12:03 PM
nightcrawler_8
bump bump ... any more ideas... want to know what to tell them if they start to play smart on me..
Old May 7, 2007 | 12:26 PM
Road Warrior's Avatar
Road Warrior
+2 on taking it in asap...its a sports car so driving it hard should not even be an issue really...but just tell them the story minus the racing part. you don't have anything to lose at this point...except paying for the problem after your warranty expires. taking it in would at least give you documentation down the road after the warrany if there is a problem...and then you would be covered.
Old May 7, 2007 | 12:32 PM
Nick@GTM's Avatar
Nick@GTM
GT Motorsports
Wouldn't be too concerned there nightcrawler. This noise is very common have heard this in practically all z's i have driven when shifting as you described. You are hearing the rear differential housing shifting on the rubber isolator bushing under those torque application scenario's. the factory used this type of bushing to isolate nvh, this is normal don't worry
Old May 7, 2007 | 12:34 PM
nightcrawler_8
the reason why am concerned is that my buddy have Z and he was surprized when he was setting next to me .. and he was like WTF ????? what was that sound....
i heared it before but i thought its normal..
Old May 7, 2007 | 04:06 PM
Eithan Z 1's Avatar
Eithan Z 1
I have the same noise... like a big bump when shifting on high RPM, i think its normal.
Old May 7, 2007 | 04:08 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Sounds to me like your letting the clutch out too quickly before giving it gas, thus not shifting smooth and producing a thud every shift. Shame on you for having a Z and not realizing you needed practice earlier!
Old May 7, 2007 | 08:43 PM
nightcrawler_8
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
