5th gear grind
Old May 7, 2007 | 09:08 AM
Cannysage's Avatar
Cannysage
Default 5th gear grind
I have JWT and started experiencing this
you think my tranny is shot? all other gears are perfect.. is this
repairable?
Old May 7, 2007 | 09:51 AM
andypandy's Avatar
andypandy
what year is your car?
it is repairable but not at all worth it. to minimize the grinding, i suggest you to let the revs catch and slowly shift into 5th. it's a good way to remedy a synchromesh transmission with an ailing synchro.
Old May 7, 2007 | 09:59 AM
JCat's Avatar
JCat
=Yes.
=If you have less than 60,000 Nissan will replace it for free.
(I was wondering if an aftermarket flywheel/clutch/pressure plate setup would affect the 5th gear syncho going bad.....thanks for answering that.)
Be sure to ask for the CD009 model tranny. If you have a 2004+, they will attempt to give you a CD008.
Old May 7, 2007 | 10:20 AM
Cannysage's Avatar
Cannysage
Mine's a 04, has an after market clutch (JWT)
Old May 7, 2007 | 02:45 PM
Cannysage's Avatar
Cannysage
Old May 7, 2007 | 03:38 PM
THE ROADSTER's Avatar
THE ROADSTER
repairable?
HAHA, I got the same set up with JWT TT and JWT clutch and my car is at the dealer for a new tranny because of 5th gear grinding, 13,000 miles.
Old May 7, 2007 | 04:16 PM
Cannysage's Avatar
Cannysage
how much are you getting charged for this.. this voids warranty, right.. phug..
Old May 7, 2007 | 04:31 PM
THE ROADSTER
I told them it's a common problems with 2003/2004....no charge
Old Aug 9, 2007 | 07:33 PM
sirsambo's Avatar
sirsambo
What dealership did you go to?
Old Aug 10, 2007 | 06:38 AM
THE ROADSTER
Mike with VRT who did the tunning on my car had connection with Mossy Nissan in El CaJon, Sandiego.
Old Aug 10, 2007 | 10:18 AM
clipso 01's Avatar
clipso 01
search for transmission grind, there are a ton of threads on this problem
Bad Synchros
Old Aug 10, 2007 | 11:04 AM
Iconoclast1's Avatar
Iconoclast1
how do syncros go bad? or break...?
what sort of driving habits cause them to do so?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
