problem with acceleration, possibly clutch???
Old May 17, 2007 | 02:44 PM
jaida86's Avatar
jaida86
Default problem with acceleration, possibly clutch???
So i have a problem. I have notcied while i am driving casually lets say at 25 in 1st or 2nd gear if i punch the gas my revs spike up dramatically without any power connecting to the drivetrain. less than a second later as the rpms drop it catches and then procedes to accelerate as it should. now mind you this isnt how i drive on a regular basis going around jamming my throttle but i know its not right. if i am in 5th or 6th lets say going down the freeway at 65-70 and want to accelerate even if i slowly put on the gas it acts as if the clutch is still in it revs up without actually speeding up then drops down and procedes to speed up.
I am very frustrated seeing as i had a new clutch put in the damn thing not even 3 months ago.
also if in 5th and 6th as stated as above if i punch the gas i get the nice smell of a burnt clutch when it finally leaves the high rev point and comes back down.
if anyone can please shed some light on this it would be very helpful.
thanks
Jack
also sorry for any spelling errors i am at work and am trying to to be on very long.
Old May 17, 2007 | 04:44 PM
jaida86's Avatar
jaida86
bump, anybody?
Old May 17, 2007 | 05:07 PM
97supratt's Avatar
97supratt
Easiest way to tell if your clutch is gone, get on the highway and put it into 6th gear. Punch it, if the revs fly, your clutch is bye bye.
Old May 18, 2007 | 05:03 AM
CLETUS's Avatar
CLETUS
sounds like a clutch to me. my buddy has the same problem right now. he is getting the JWT clutch and flywheel.
Old May 18, 2007 | 10:05 AM
PP White Z's Avatar
PP White Z
You need a new clutch.
Old May 18, 2007 | 11:36 AM
ke0ki2k's Avatar
ke0ki2k
what kind of clutch did you have put in? do any drag racing?
Old May 18, 2007 | 12:26 PM
jaida86's Avatar
jaida86
no drag, just drift
it was a ACT clutch/flywheel
Old May 19, 2007 | 12:40 AM
gsazabi's Avatar
gsazabi
Originally Posted by jaida86
no drag, just drift
You might have burned out your clutch already.
Aftermarket clutches don't allow as much slippage as stock, so if you've been slipping and riding your clutch you can burn it out in few thousand miles.
Old May 19, 2007 | 11:05 AM
ke0ki2k's Avatar
ke0ki2k
driftin? lol not with those mods. you gotta have a 1.5 LSD or you'll be one wheeling it. you might throw the rear end out but you're not really drifting it lest its wet and your VLSD doesnt kick in.
Old May 19, 2007 | 12:24 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
You can "drift" just fine with even an open diff - it's got everything to do with weight transfer, and little to do with what "diff" you run. Equipment does not make you a better player automatically -no matter what the game.
Anyway, that being said, to the OP, your clutch is shot. Why is it shot? Couple of potential reasons, but you wont have the answer till you take it out of the car. In all liklihood, you either did not break the clutch properly, or you excessively slip the clutch during normal driving. No matter what clutch you have, from a $500 ACT to a $5000 Tilton, you can literally kill it in as little as 1000 miles if you really "wanted" to.
Old May 20, 2007 | 10:42 PM
jaida86's Avatar
jaida86
keoki2k,
i was going to say.... i may have only had my z for almost a year now, but ive been drifting for almost 3 i need no explanation ace... thanks
Z1,
thank you for your response. I guess i should have provided some more info as well. my car has now been registered as non-op for track use only due to regulations. they will be pulling the clutch this coming weekend. i will post updates afterwards
Uriyo_
Sep 8, 2021 08:46 AM
_bit
Oct 2, 2015 07:49 AM
