3.9FD installation parts?
Old May 25, 2007 | 01:34 PM
cavallino33's Avatar
cavallino33
Default 3.9FD installation parts?
I'm going to be getting a Nismo LSD and 3.9 FD in a few days here. I have a couple questions about the installation part. I did a search and found alot of threads about the 3.9Fd but answering my specific question. If I did happen to miss the answer in a previous thread I apologize and please point me in the right direction.
Anyway heres the issue. The Nismo LSd comes with all the parts needed for the LSD install but the 3.9 needs seperate parts. It's my understanding that I need the pinion seal, crush sleeve and pinion nut; and the ring nuts, front/rear pinion bearings and carrier bearings if the car is of a certain age.
Now my 06 base model Z only has about 2010 miles on it is it necessary to replace the ring nuts, front/rear pinion bearings and carrier bearings for a car with this few miles? I don't want to cheap out on anything but I don't want to go spending money frivolously if I don't need to. I'll be getting everything installed at Z car garage.
Any help would be much appreciated. Thanks.
Oh and if I'm forgetting anything please chime in.
Old May 25, 2007 | 03:25 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you'll only need what we call the install kit 1 - the crush sleeve, pinion nut and oil seal
the rest you can easily reuse as your car is so new
Old May 25, 2007 | 03:27 PM
cavallino33
Ok thats what I thought.
Old May 29, 2007 | 12:17 PM
dal2kvvisp's Avatar
dal2kvvisp
tell me how it goes over at Zcar Garage, im also interested in doing a similar setup, i had them dyno my car right when i got it. they seem pretty cool over there
Old May 29, 2007 | 12:24 PM
Fluid1's Avatar
Fluid1
This isn't totally correct. You'll also need some shims of some size, and you can't tell what size until you ahve the car opened up. This has been discussed many times.... the best place to have the work done would be one that has on hand every size shim. Example (as much as I hate them) the Nissan dealership.
Old May 29, 2007 | 12:37 PM
cavallino33
Yes I know about the shims. I talked to Rob at Z car garage this morning he said they had the shims and all the necessary installation parts available.
I did call a nissan dealer just for the hell of it they wanted over 1K for install which is ridiculous.
Old May 30, 2007 | 12:04 PM
MDubbsZ's Avatar
MDubbsZ
I had my 3.9 installed at ZCarGarage. They did a great job on the install and are very professional.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
