JWT flywheel/cluth nightmare
Old May 30, 2007 | 07:19 AM
slickwilly23's Avatar
slickwilly23
Default JWT flywheel/cluth nightmare
I wanted to see if anyone else has had a similar experience. I installed the JWT flywheel and clutch at the end of last summer and now about 2,000 miles later (I took it off the road for winter), I am experiencing tons of problems. I heard a rattle at first and took it to a shop to be checked out and they told me it was probably just a loose bolt, so went back to where I had it installed to have them fix the problem since after 2,000 miles it seemed like an error in their workmanship. Today I found out that the flywheel had sheared all the bolts and basically destroyed the clutch and possibly the camshaft. They're saying this is because the the Aluminum flywheel is not compatible with the car since it expands a lot more than steel, which is how the problem came about in the first place. So basically I'm looking at about a $3,000 dollar repair. Has anyone else heard of this with the JWT flywheel, because if its not compatible I would think there would be more cases of it.
*Also I know it's clutch in the title, so I don't get flamed for a typo*
Old May 30, 2007 | 07:26 AM
philude's Avatar
philude
wow, this is the first i've heard of this problem. i hope it all works out well for you...i've been considering this combo, but would like to hear if this is going to be a problem...
Old May 30, 2007 | 07:32 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
I have my JWT combo in for awhile now and no problems here. What you posted does sound like an installation problem vs. a defect in the product. While a flywheel even worlk if it's not clocked right?
Old May 30, 2007 | 07:37 AM
97supratt's Avatar
97supratt
That bull$hit, those flywheels are perfectly fine. It's the installer that messed up.
Old May 30, 2007 | 07:49 AM
slickwilly23
I know they said they had a problem with someone else who had an aluminum flywheel that expanded and backed the bolts out, but mine expanded I guess and sheared the bolts. So I'm going with the Nismo one now, and not risking it again.
Old May 30, 2007 | 07:50 AM
philude's Avatar
philude
so they ****ed up and you have to pay?
Old May 30, 2007 | 07:54 AM
97supratt's Avatar
97supratt
If you are referring to the flywheelbolts then they probably didn't torque them down to spec. Bolt's don't just come off, lol.
Old May 30, 2007 | 07:59 AM
slickwilly23
yea mine weren't the ones that backed out, my bolts sheared off so they are currently trying to get whats left of them out of the camshaft to salvage that. My father went to check on the car today and said the JWT flywheel was looking pretty warped and messed up. It's possible that they screwed up in the install but there's no way to prove it.
Audible Mayhem's Avatar
Audible Mayhem
My350z
sounds like some installer error, there are tons of JWT clutch./flywheel combos around...
Old May 30, 2007 | 08:00 AM
350Z_LEE's Avatar
350Z_LEE
Sounds like the technicians error.
Old May 30, 2007 | 08:02 AM
97supratt's Avatar
97supratt
Trust me they installed it incorrectly. The crankshaft might be damaged especially if the flywheel was a bit loose. Some minor vibrations can be absorbed but if it moved quite a bit, you could ruin bearings that way.
Good luck man, I hope everything works out.
Old May 30, 2007 | 09:16 AM
jpc350z's Avatar
jpc350z
18,000 miles with the combo and 11,000 of them with the Vortech S/C..Your's was installed improperly!!
Old May 30, 2007 | 09:24 AM
jpc350z's Avatar
jpc350z
I guess it is also possible your flywheel may not of been balanced and produced some wobble loads into the crank??
Old May 30, 2007 | 10:05 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
+1. They should have used some blue loctite on those flywheel bolts. we have never had any flywheel bolts come loose.
Old May 30, 2007 | 10:10 AM
zland's Avatar
zland
Sport Z Magazine
Best to have someone work on your car that you are sure knows what they are doing. Unfortunately, many dealers & auto repair places hire mechanics with limited trainning or experience. Just because you are being charged $80 per hour + does not mean you have a qualified tech working on your car.
Old May 30, 2007 | 10:37 AM
Changvi's Avatar
Changvi
Yeah, for sure they messed up your Flywheel setup. I have mine for about a few thousand miles with no problems. Even with Nismo clutch setup as well. They guy was BS you bro. Take it somwehere else to have the relair done. You don't want to have them mess up your transmission again.
Old May 30, 2007 | 01:21 PM
clipso 01's Avatar
clipso 01
wow sorry buddy that sucks. Sounds like an installer error
Old May 30, 2007 | 01:57 PM
LG_z33's Avatar
LG_z33
If your crank bearings are shot due to a faulty install, consider taking legal action. A rebuild will be thousands.
Old May 30, 2007 | 03:22 PM
jonnylaw's Avatar
jonnylaw
One reason why I'm having my dealer install (and warranty) the work on my integrated clutch/flywheel install, despite having a severely sore bum due to the bill of 9 labor hours.
Old May 30, 2007 | 04:36 PM
Ztalker's Avatar
Ztalker
small claims court is your friend.
B Esquire
Sep 24, 2015 07:52 AM
