Clutch Break In
Old May 28, 2007 | 11:50 PM
jonnylaw's Avatar
jonnylaw
Default Clutch Break In
Tried Searching, but didn't see any results. Can someone please chime in on the suggested way to break in a new aftermarket clutch and flywheel? I assume no launching, but anything else I should do/not do?
Old May 29, 2007 | 01:15 AM
Cloud's Avatar
Cloud
The ORC manual stated that you should just drive normally for 500km.
Old May 29, 2007 | 05:27 AM
WalkerT's Avatar
WalkerT
Professional
I keep the rpms low for shifting for the first 1000 miles and no high rpm down shifts.
Old May 29, 2007 | 05:31 AM
halfass872's Avatar
halfass872
Don't know about aftermarket. But when i had my stock clutch and flywheel replaced under warranty, it slipped a bit and smelled for the first few hundred miles. After that it was good to go! Just take it easy for a while.
Old May 29, 2007 | 01:30 PM
LG_z33's Avatar
LG_z33
Drive normally for 500 miles while avoiding any high rpm clutch drops or shifts. The point of a break in is to seat the surfaces while avoiding any glazing. High heat generated from high rpm shifts can glaze the clutch and ruin its lifespan.
Old May 29, 2007 | 03:33 PM
gabez33's Avatar
gabez33
wow good post! thanx I just got mine replaced...well actually just the plate...should I also follow the break in? The dealer said nothing to me about it!
Old May 29, 2007 | 05:07 PM
LG_z33's Avatar
LG_z33
The new surface of the clutch plate needs to be broken in so i would definately recommend the standard 500 mile break in.
Old May 29, 2007 | 05:10 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
I was told 400-500 stop-n-go miles.
This article came up in a Google search, last question:
T: Why is clutch break-in so important?
S: We recommend 200 to 300 miles of mellow usage for our street discs. The purpose of breaking in a clutch is to engage the disc in a controlled, consistent manner to ensure the disc, pressure plate and flywheel all make full surface contact. It's also a chance for the friction material to experience normal heat cycles.
http://www.turbomagazine.com/tech/04...h_tech_basics/
Old May 29, 2007 | 11:06 PM
jonnylaw's Avatar
jonnylaw
Good stuff!
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
