Swapped seats but didn't disconnect battery & salvage weight sensors what's next
Old Sep 26, 2024 | 08:16 PM
Ryan_vq35's Avatar
Ryan_vq35
Default Swapped seats but didn't disconnect battery & salvage weight sensors what's next
As title reads, I sold my OEM nismo seats to upgrade to some Recaro SR-6. In the process I sold the seats with all equipment underneath which I felt was the proper thing to do, but I wish I kept the original pair in hindsight. Recaro SR-6 are mighty tight but fit me well.
This is my problem. I was super ancy to get the seats in the car and I think I was in a rush to sell the others that I simply took both out while car was off but battery connected whilst unplugging the cables to them. I had been driving with airbag lights for months but I want to fix it now.
I have 2.2 ohm resistors but need assistance identifying which cables in pic you shove them into?
Then from what I understand you do the key reset into service mode thingy.
But I believe the passenger seat has a weight sensor I also need to purchase the occupancy emulator linked here (1 or 2?)
https://airbag360.com/nissan-350z--o...1018-472-p.asp
Really just want these airbag lights off before winter since I won't have my car in garage much longer
Old Sep 27, 2024 | 12:18 PM
icer5160's Avatar
icer5160
SRS harness plugs are yellow. This is an industry standard. You will need to look up a wiring diagram for the weight sensor, that could be any one of those white plugs. I hope you plan to keep your car long term, if it's a legit Nismo, the Recaro seats will actually drop the value.
Cheers!
-Icer
Old Sep 27, 2024 | 01:00 PM
Ryan_vq35's Avatar
Ryan_vq35
Cheers!
-Icer
its a legit nismo, #1132
I do plan on keeping long term, as my dream car is a gt4rs. This car keeps me satisfied until that point which is a long way down road as I’m still young (27) I plan to pass on this car to my kid someday if I ever have one.
Totally understood what selling stock seats would do to value but unfortunately I had no place to store them at the time, live and you learn… the stock seats were literally just red base seats. Not much bolster at all
It’s quite difficult to find any instructions on how or where to shove resistor in place
To anybody considering changing seats, definitely do your research. Has been the most time consuming project with this car for sure and not the easiest to pull in and out obviously when you are working on the car
Old Sep 27, 2024 | 05:58 PM
icer5160's Avatar
icer5160
Yes, the base/cloth seat side bolsters tend to wear out quick. The foam cushioning cracks against the metal bucket/frame. The driver's seat thigh bolsters always blow out 1st. I had my lower seat bucket professionally re-upholstered by a shop in the Belmont area. The Guy did great work, re-used the OEM seat cover since that was in excellent shape. I think the upper torso bolsters are adequate for daily driver use, but I have broad shoulders so your mileage varies.
I'm glad I have an Enthusiast, I don't need to worry about the seat weight sensor or seat airbags. Simply the seatbelt buckle harness, nothing more. Don't even need to disconnect the battery to remove the seats.
Good Luck! Hope you get it sorted.
-Icer
Adon
Jan 31, 2013 08:16 AM
Armitage
May 10, 2011 01:50 PM
cracka350z
Oct 1, 2007 05:23 AM
