stillen engine dampner problem.
Old May 29, 2007 | 02:09 PM
nathanwl2004's Avatar
nathanwl2004
Default stillen engine dampner problem.
so I installed the stillen engine dampner last night. but the first few times that I started the car afterward it would die immediately after starting. I would try it a second time and it would work fine.
well now every time I start out in first gear I can feel a very very very noticable vibration in the pedal (clutch and gas) and even at idle the car vibrates more that it did pre install.
I think that for some reason the dampner might be to tight. or something and it is not allowing the engine to vibrate at idle the way it naturally does.
I am gonna mess with it a bit today and see if I can fix it and if not I will probably just take the whole unit out.
any suggestions, anyone else have a similar problem. is there a possible fix?
Old May 29, 2007 | 06:19 PM
gargoyleZ's Avatar
gargoyleZ
If you read thru the threads on this mod, you will see that vibration is a normal symptom. Logically, you are connecting the engine to the frame.
The stalling of your vehicle is not normal, check to make sure your grounds are on tight.
Old May 29, 2007 | 09:50 PM
Mazinger Z's Avatar
Mazinger Z
Don't have a dampner, but your engine dying is def. not normal. Did you have to remove anything (hoses, bolts, lines,etc) to install it? Make sure those are tight...even if there's a leak somewhere, your engine shouldn't die like that.
Old May 30, 2007 | 12:16 AM
LG_z33's Avatar
LG_z33
+1
The vibration is normal as the engine is connected to your frame with this mod.
The stalling is not normal and should be investigated further.
Old May 30, 2007 | 12:31 PM
nathanwl2004
even the vibration in the pedals. I've read the other threads and from the sounds of it most people have had some small vibrations but I've not heard anyone that has vibrations like this. perhalps the ground wire needs to be tightened.
what happens when I start the engine is very odd. sometimes when I start the motor it will try to start and then stall down to 0 rpms, but then it will like come back to life and start going again. it's quite strange. maybe someone can elighten me as of what to check for?
Old May 31, 2007 | 07:17 AM
halfass872's Avatar
halfass872
Originally Posted by nathanwl2004
......it will try to start and then stall down to 0 rpms, but then it will like come back to life and start going again....
Def sounds like a vacume leak.
Old May 31, 2007 | 07:43 AM
mikead_99's Avatar
mikead_99
It does doesn't it, but it would be hard to create one installing the dampener. I would look at the ground that had to be moved to install.
edit to add: this doesn't explain the excessive vibe either, I wonder if one of the motor mounts is bad too.
Old May 31, 2007 | 11:07 AM
bbs350z's Avatar
bbs350z
i installed mine yesterday actually (stillen) i did not have to remove the ground wire like it said. if it sputters and dies, it definately sounds like a vacuum leak of some sort. check all the hosing, etc.
other than that, just make sure that you put the power steering and coolant tanks back after. other than that it was relatively simple. just make sure that you put the damper into the bracketand all hex bolts in before you go to bolt it down ther otherwise it'll be a pain in the ***
Old Jun 1, 2007 | 08:18 PM
nathanwl2004
I've had minor problems with it ever since I installed my pop charger. but they have never been so bad that the car would actually die. it would always loose rpms on start up and then it would go right back up.
is there any technique I can use to investigate this further?
Old Jun 2, 2007 | 10:28 AM
Netko350Z's Avatar
Netko350Z
Check you MAF sensor. Your popcharger oil might have got all over it. Take it out and clean it. Search for how to clean it. I can't remember what the cleaning stuff to use was.
Old Jun 2, 2007 | 12:16 PM
GreenGoblin's Avatar
GreenGoblin
check all the hoses and see if they are brittle and could have some cracks that it is leaking
Old Jun 2, 2007 | 12:40 PM
bacalhau16's Avatar
bacalhau16
Was there anything that you had to unplug when you installed this? Perhaps just try taking out the negative terminal on the battery and resetting the ecu.
Old Jun 2, 2007 | 03:18 PM
nathanwl2004
not exactly sure what to look for. which lines are the vacume lines? if I knew that then I would know what to check for.
Old Jun 3, 2007 | 07:34 AM
nathanwl2004
bump
Old Jun 3, 2007 | 09:12 PM
bacalhau16's Avatar
bacalhau16
did you try resetting the ecu?
Old Jun 4, 2007 | 03:41 PM
gargoyleZ's Avatar
gargoyleZ
If it were a vacuum leak, I believe that the idle would be high and erratic. Did you relocate the ground wires like the instructions say?? I still think you are not getting a good ground. There are no vacuum lines to disconnect, or hoses to move during this install.
The vibration is definitely normal. Even in the pedals...excessive is relative (imho) as you are going from no vibration to having it, thus you are going to notice it more (make sense?).
Maybe go over the install again, and make sure that all your wires are tight, and hoses are re-connected (although I dont remember disconnecting any hoses when I did it).
GL
Old Jun 4, 2007 | 11:30 PM
350ZTheStandard's Avatar
350ZTheStandard
Cool
When I installed mine there were no vacuum hoses that I removed, I did move the ground from the block to the front of the alternator, make sure you tightened all hardware, including the ground. Check the battery connection on the negative cable, lastly make sure the battery has juice.
As for the new vibrations yes the dampner is working, I adjusted mine just as tight as I could get, you will notice the vibrations for just a couple of days. Good luck
Old Jun 9, 2007 | 12:20 PM
nathanwl2004
hey guys, sorry it's been a while since have been on. just to give you guys an update.
the vibrations seem to be slowly becoming more tame and tolerable. I'm not sure whether I am just becoming more used to it or that the engine dampner is breaking in slightly and there for not transmiting as many vibrations to the frame.
as for the engine dying. I had reset the ECU a few times. and it would only seem to hurt the problem. it seems as the ECU would learn more the problem would go away slightly but not completely. it would still die about 30 percent of the time.
it seems as if the engine would work better on the very first start of the day and when the engine was colder.
after thinkin about it for a while and checking every hose that I could get to I finally thought to check the intake plenum spacer and see if it was sealed properly. I went to check the bolts on and most of them seemed very lose. I could easily break the bolts free with minimal effort, and they seemed as if they had alot of room to tighten. after I tightened bolts I started the car and it seemed to start normal (but like I said it usually does during the first start of the day). well I again checked the plenum spacer bolts and they still seemed a little loose plus I heard a slight hissing sound around one of them. when I tightened the bolt the hissing sound went away.
I haven't had a chance to drive it since but I will be shortly. I'm just wondering could this be a possible vacume loss that would cause the car to behave this way?
+ I just wanna thank you guys for all the help and advice you guys have given me.
my350z.com FTW
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
