Weak engine, need help or suggestions please.
Old Jun 9, 2007 | 07:42 AM
gabez33's Avatar
gabez33
Default Weak engine, need help or suggestions please.
I have noticed that my Z is considerably weaker than every other Z I have owned and drove. It was having tranny issues, so I thought that might be the problem. Well took it to the dealership got a new tranny (CD009) and clutch plate. Car feels better, shifts really well, but still lacks power. Ive done almost a complete tune up excluding plugs(K&N filter, RP oil change, fuel sys cleaner, MAF cleaner, new battery old one died, ect... The car just feels like its lacking HP, its gotten to the point that I have thought of trading it in. I give it gas, and I do get initial power, but then it just tappers off. And you can hear the engine working and roaring but the car feels like its running on half an engine. Is there maybe something else in the powertrain that could be robbing power that I should look at getting replaced? It feels like something just isnt putting the power to the wheels like it should..or maybe just a weak engine! ANY help would be much appreciated!! thanks in advance!
Old Jun 9, 2007 | 07:47 AM
reptile718's Avatar
reptile718
Add a Turbo or S/C and it will fix the problem
Old Jun 9, 2007 | 08:15 AM
rythex's Avatar
rythex
So... you haven't had a dyno done...
Old Jun 9, 2007 | 08:21 AM
HondaKiller's Avatar
HondaKiller
yeah, get the dyno done, sounds like a case of paranoia or just getting used to your car. Car's are like women bro, great at first, stays good through out but eventually you have to upgrade them to keep that same rush
Old Jun 9, 2007 | 09:19 AM
gabez33's Avatar
gabez33
hahaha thats a good one, Yeah am going to get a dyno next week, Ill go from there I guess
Old Jun 9, 2007 | 09:22 AM
soleil's Avatar
soleil
NolaZcc
do u any mods?
Old Jun 9, 2007 | 09:30 AM
LG_z33's Avatar
LG_z33
Are you comparing your current 350Z to other 350Zs you've owned and driven or older modles like the z32(300zx)?
The powerband of the vq35 is much smoother and broader than it predecessor vg30.
However, if you're comparing it to other z33s you've driven then i dont know what to tell you without a dyno.
Old Jun 9, 2007 | 01:30 PM
gabez33's Avatar
gabez33
yeah other z33 that I have owned and driven ...I need to get a dyno
gabez33's Avatar
gabez33
no mods either
Old Jun 9, 2007 | 05:11 PM
halfass872's Avatar
halfass872
Just get rid of it and buy an RSX!!! Problem solved!
Old Jun 9, 2007 | 05:24 PM
VIZAGE's Avatar
VIZAGE
I knew someone would throw the RSX in there. But yea, put it on the dyno if you worried. Some days I think mine is weak a little and the next it will surprise me.
Old Jun 9, 2007 | 09:55 PM
FORZWIN's Avatar
FORZWIN
Best mod I ever did to my Z was the 89 Honda Civic I bought, lol. After getting out of that, the Z feels just amazing in a straight line!
But seriously, put her on a dyno and post the results.
Old Jun 10, 2007 | 02:22 AM
halfass872's Avatar
halfass872
+1 I drive a neon 6 days a week to work. So when i do get time to drive the Z, it feels brand new everytime!!!
Old Jun 10, 2007 | 03:31 PM
UrbanTacticZ's Avatar
UrbanTacticZ
Well torque does fall off after a certain point, maybe that's what you are running into?
Also, have you tried a simple ECU reset? I'm assuming it's not throwing any codes either. Did you touch any of your intake system? TB, plenum, etc? Check all the bolts and make sure everything is on tight. But, if someone was wrong, it would probably be throwing a code...
Tough to say without someone else driving it who owns a Z33!
I would just take it to a dealer and go for a ride with a tech and see what they say.
Good luck!
Old Jun 10, 2007 | 03:37 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The butt dyon can be very deceiving. Please get some baselines done on a local dyno and report back.
Old Jun 10, 2007 | 04:19 PM
gabez33's Avatar
gabez33
ok, thanks for all the replies...I will get a baseline dyno next week and go from there
Old Jun 11, 2007 | 07:35 AM
gothchick's Avatar
gothchick
werd
Attached Thumbnails Weak engine, need help or suggestions please.-godsride-1-.jpg   Weak engine, need help or suggestions please.-539630763l3od-1-.jpg
Old Jun 11, 2007 | 07:42 AM
Blu_Blur's Avatar
Blu_Blur
No, don't do this because you could be spending a lot of money on an engine that is not potentially worth it. On top of getting a load-based dyno done, I would also suggest a leak-down \ compression test done to make sure your car is holding enough compression.
How many miles is on the car?
A cmopression test will tell you if your cylinders is holding enough compression which is the key to making horsepower.
Another, more simple thing you can do, is check your tire pressure and make sure they are up to spec as adding a few extra psi can make the car noticeably quicker.
Old Jun 11, 2007 | 02:01 PM
gabez33's Avatar
gabez33
Its an 03 with 27k, A compression test huh?!?! OK, I will ask for this to be done when I go to the dealership tomorrow. do you think I should go ahead and change my plugs?
Old Jun 11, 2007 | 02:04 PM
UrbanTacticZ
Maybe I missed something while I was off of the boards for a few months but what's the deal with so many people on the 350z boards saying "buy an RSX" or "the RSX is better than the Z..."
The K20 is going to get played just like the B series has BAH!
