What LSD do you recommend?
Old Jun 11, 2007 | 02:16 PM
Laughitup85's Avatar
Laughitup85
Default What LSD do you recommend?
I've read up on a lot of different types of LSD's: Nismo, Cusco, Quaife, etc. I think I'm going to end up going with the Quaife LSD, but is that a wise choise, (I'm getting a LSD reguardless so don't worry about that) and if it is where is a place where I can buy them cheap online?
Old Jun 11, 2007 | 02:36 PM
Vader007's Avatar
Vader007
My first choise would be the Carbonetics (old ATS) for the same money or less than the Quaife, my second choice would be either Cusco RS 1.5 or the Tomei Trax 1.5. Just my personal preference.
Fluid1's Avatar
Fluid1
Why?
Old Jun 11, 2007 | 02:37 PM
Fluid1's Avatar
Fluid1
What model Z do you have?
what are your goals for the car/LSD?
Old Jun 11, 2007 | 02:50 PM
Equinox's Avatar
Equinox
What do you intend to use the car for? Open track? drift? autox? street? drag?
Old Jun 11, 2007 | 03:02 PM
Laughitup85
I have an 03 touring and I'm going for street and drag
Old Jun 11, 2007 | 07:05 PM
Equinox's Avatar
Equinox
Since you have a touring, I would suggest the Cusco RS 1.5way. It should be very quiet for street use and durable enough for drag racing. Price-wise, I belive it is less expensive than the Quaife and Carbonetics LSDs.
Old Jun 11, 2007 | 07:10 PM
Laughitup85
thanks I'll look into it a little more. it should be about 2 weeks before I have the money to buy it.
Fluid1's Avatar
Fluid1
However, it is a clutch type LSD. It is going to have more noise than stock. There's some good threads about diffs and fluid and sound.
I would have to recommend it over the Quaife only because you don't have the Base Z, which the Quaife is designed for.
Old Jun 11, 2007 | 07:11 PM
Fluid1's Avatar
Fluid1
How much research have you done on LSD's? I wouldn't go buying one without learning up first. How many miles are on your OEM lsd?
Old Jun 12, 2007 | 09:24 AM
cy350's Avatar
cy350
both Cusco and Quaife are on my list too. I heard Quaife is more quiet and it work very well too.
Please share your experence after install as a reference for my dicision.
Old Jun 12, 2007 | 09:49 AM
Laughitup85
I know that I need one if I want to get better traction for drag, I also know that LSD's are better in general especailly when losing control. and my OEM lsd has 43,000 miles
Old Jun 12, 2007 | 09:50 AM
Laughitup85
will do and i've heard the same thing about Quaife
Old Jun 12, 2007 | 09:57 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
A Quiafe is a gret diff, but to put it into a non base, you are looking at nearly $1800 - hardly worth it at that point
Cusco or Carbonetics/ATS is your best overall bet - and we carry both if you need em !
The secret to smooth diff operation and lack of noise is using the right setting for your useage, and using the right fluid - my Cusco is no more intrusive than stock
Old Jun 12, 2007 | 09:58 AM
IIQuickSilverII's Avatar
IIQuickSilverII
I like Cusco myself
Old Jun 12, 2007 | 10:00 AM
Laughitup85
can you PM the prices? and my friends and I install all of the MODS ourselves.
Old Jun 12, 2007 | 10:03 AM
Z1 Performance
Former Sponsor
Pricing is on our site for all the diffs we offer:
http://www.z1auto.com/submodel.asp?m...&cat=driveline
Any questions, just ask!
Old Jun 12, 2007 | 10:05 AM
50 Freak's Avatar
50 Freak
Good suggestions guys, I have a new 06 Base I'm looking to put a LSD on. Which one do you guys suggest????
I only plan to use it for normal street driving and "limited" street races everynow and then with those pesty BMW 325s that seem to plague the roads here.
Old Jun 12, 2007 | 10:12 AM
Z1 Performance
Former Sponsor
for a base that sees the vast majority of its time on the street, the Quaife is your best bet:
http://www.z1auto.com/prodmore.asp?m...ne&prodid=2349
Old Jun 12, 2007 | 10:15 AM
Laughitup85
so when I'm looking at buying a LSD and I have the touring model. does that mean I don't have a factory LSD or I do?
