PO340 Camshaft Position Sensor
Old Jun 13, 2007 | 01:11 AM
bizcotch's Avatar
bizcotch
Exclamation PO340 Camshaft Position Sensor
Cruising on the freeway when all of the sudden it seem to not want to go forward(running out of gas feeling). then, it ran normal . Parked it for about 2 hours and when i wanted to start it up again, it simply took about 5 seconds to get the engine running; however, the Engine light along with the TCS and Slip came on. I hooked it up to the OBDII reader and gave me the PO340 code for Camshaft Position Sensor. I got a couple of questions:
1.will Nissan cover it under warranty as power/drivetrain problem/60,000 or will i end up paying for it(car has 50,000miles)?
2.If not, how can i tell which sensor is the culprit, right or left?
3. Anyone have a picture of where they are located? Each cost about $50.00.
THanks!!!! your help is much appreciated.
Old Jun 13, 2007 | 06:18 AM
justusS's Avatar
justusS
Backside of the engine. Starting straight from the top rear of the intake, look down and you should see one to the left and one to the right. One of them is a little harder to see.
I think one has a 90 degree angle in the connector and the other is straight.
Don't think you can buy the individual sensors from Nissan...you have to get the whole set (120-130$). Maybe can get individuals from auto parts store, but don't know how those would work
I have a replacement set (all 3) still in packaging. Bought for an 03' but I don't think it's year dependant.
Old Jun 13, 2007 | 06:22 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
The code will tell you bank 1 or 2. Also, depending on year I believe there was a recall/TSB on these for certain cars. Should be covered under warranty either way
Old Jun 13, 2007 | 08:00 AM
bizcotch's Avatar
bizcotch
Thanks for the Info. ... going to check it out again today and try to find the location of these "sensors".
Old Jun 13, 2007 | 08:02 AM
bizcotch's Avatar
bizcotch
I guess i'll end up taking it; however, i hate taking my car to the dealer. They always screw something else up
Old Jun 13, 2007 | 10:37 PM
justusS's Avatar
justusS
Let me know if they are going to charge you....Maybe can work something out. Crank is pretty easy to get to. The Cam's can be a little of a pain (moreso if your turboed)
Old Jun 14, 2007 | 07:15 AM
bizcotch's Avatar
bizcotch
Called the "stealership" and asked:
ME-assuming that the car is throwing a PO340 code, will it be covered by powertrain warranty60,000?
Service Guy- No, its an emissions problem and is only covered under the 36,000/3yr. However, we need our technician to see it first to see if its not anything else.
THerefore, i went to the dealership and bought the sensor bank1 right hand side(59.00). It only took about 15minutes to replace and now the car runs like a champ!!
2ndchanceZ
Oct 26, 2015 08:03 PM
Depravity
Oct 1, 2015 04:49 PM
