Manual Transmission Whining
Old Jun 16, 2007 | 07:28 PM
cornishteeth's Avatar
cornishteeth
Exclamation Manual Transmission Whining
I recently changed out my manual transmission oil and switched to Royal Purple Synthetic. When I first start the car after it sitting all night and drive it, the transmission whines. It only whines when under a load and near the point of shifting up to the next gear (2K-4K RPM). This only last until the oil heats up, approx 2-4 minutes of driving. I followed the tech manual and used the right oil. Could this just be a characteristic of using a synthetic? Has anyone else had this happen?
Old Jun 16, 2007 | 07:39 PM
SteevoZ's Avatar
SteevoZ
how loud is the whining?
Old Jun 17, 2007 | 12:49 AM
DJMatrix1067's Avatar
DJMatrix1067
did you use gl4 or gl5?
Old Jun 17, 2007 | 12:42 PM
silver350tn's Avatar
silver350tn
i am about to switch to royal purple gear oil too which kind do i need? and where can i find it ? thanks in advance
Old Jun 17, 2007 | 02:44 PM
cornishteeth
Default Not too loud
The whining isn't too loud, but loud enough. It's high pitched and directly proportional to the load on the transmission. As the RPM's go up the whining increases in frequency then when shifted up to a new gear it stops until you reach the shifting point, approx 3K-4K RPM. It only does it after it has sat overnight. Also, the bottle states that it's good for GL5 and GL4 applications.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
