07 free reving
Old Jun 19, 2007 | 12:50 PM
AugustXII's Avatar
AugustXII
Default 07 free reving
when i put my 07 in N and rev up to like 4rpm then let the gas drop, the rev drops freely but pause at about 2ish rpm for just under a second and then continue to drop down. is that normal???
Old Jun 19, 2007 | 12:54 PM
Blacryan's Avatar
Blacryan
Very normal. Very common. Very searchable.
Old Jun 19, 2007 | 01:01 PM
Tenac1ousZ's Avatar
Tenac1ousZ
you should get it check out ASAP....4 revolutions per minute is way too slow for any gas engine.
It's normal for the rpm to slow down at 1.5-2krpm to keep the engine from stalling. You should start worrying if it doesnt do that. My car didn't do that one time, and it turned out I had a faulty electronic peddle and had to be replaced
Old Jun 19, 2007 | 01:04 PM
Karma_Hunden's Avatar
Karma_Hunden
no moflow, he is talking about free revving, meaning he doesnt go to neutral, he just revs it and stops and then the revs drop but they stay at 2k for a second then continue dropping.
putting your car into D is bad but wont kill the tranny immediately unless you do it a few times or throughout more beating or time.
Old Jun 19, 2007 | 03:28 PM
Tenac1ousZ's Avatar
Tenac1ousZ
what the hell r u talking about?
The original poster wonders if it's normal for the rpm to slow down its descending rate near 2k rpm, after revving IN NEUTRAL and letting the rpm needle drop back down. Reread what he wrote. And what the hell is a moflow
edit: you obviously can't know what he's referring to, because you don't own a Z.
Old Jun 19, 2007 | 06:08 PM
cheshirecat79's Avatar
cheshirecat79
This is one of the byproducts of the drive-by-wire throttle, if I'm not mistaken. The rpm's will fall off at different rates because the computer is telling the engine how to spool down, not your foot. That's why it behaves differently even though your foot is doing the same thing in each situation.
Rob
Rev_Night
Nov 7, 2020 06:00 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
