Installed My Grounding Kit Today
Old May 4, 2003 | 07:48 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Default Installed My Grounding Kit Today
Got my kit from InsaneAmine a few days ago. He Fed Ex'ed it to me in only 2 day! I was OOT but got back today and put it. Looks good. Thanks very much my friend!
Your Prices are INNNNNN-SAAAAAANNNNE!
Old May 4, 2003 | 07:50 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Seems to run a little smoother. Looks great.
Old May 5, 2003 | 07:05 AM
zwindsor's Avatar
zwindsor
Twisty addict
That's the first strut brace I've seen with matching paint. Looks good with the cover.
Old May 5, 2003 | 10:44 AM
Dallas350Z's Avatar
Dallas350Z
Unhappy Need some advice....
I installed mine Sat. The wire that attaches to the left side of the intake manifold (passenger side), well, while I was tightening it, the bolt broke off with the threaded portion still in the hole.
So, I just bolted the wire to the piece behind it. It seems to work just fine....just curious if I have voided any enhancement the kit provides by using a different mounting point?
Old May 5, 2003 | 10:52 AM
zwindsor's Avatar
zwindsor
Twisty addict
Default Re: Need some advice....
None. Any clean metal grounding point is fine.
Old May 5, 2003 | 08:14 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Funny you say that. I broke one off inside the hole too. It was the top bolt of the bracket that holds the rubber hood sensor down. You have to remove the bracket to get to the main ground bolt. When I was putting it back in.......CRACK. No biggie though. The one remaining bolt holds it nice and tight.
Old May 5, 2003 | 08:42 PM
slay2k's Avatar
slay2k
Haha,
Congrats on the kit Doc.
We should start a sub-culture for those who broke off a screw while installing the grounding kits.. seems like there's hundreds of em.
-slay
Old May 5, 2003 | 11:40 PM
Brando222's Avatar
Brando222
Ziologist
Default Me too
Wheww I thought I was the only one dumb enough to break a bolt off. I broke the one that goes in the very back, directly behind the engine. I was so pissed. Had to drill into the leftover bolt and remove it, then I had to use a dirty bolt I had lying around. =)
Old May 6, 2003 | 07:16 AM
12SecZ's Avatar
12SecZ
Engine Bay looks good Bonz,
Add me to the broke the bolt off club!
The hood mount with one bolt club
And the dropped the bolt had to find it club.
Everything still runs fine though.
Hehe
Old May 6, 2003 | 10:04 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
That is SOOOO FUNNY! Here I am cursing myself when I broke that thing and I also dropped a bolt down onto the plastic cover thingy and it was next to impossible to get to. I was telling myself I was stupid to do this myself and that I should have had someone with some under the hood experience do it etc. and I find that you guys all did the same thing!
I feel MUCH better now!
Old May 6, 2003 | 02:01 PM
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
Default Hey Doc!
Hey Doc,
Looks great! Thanks for the review. You guys are great!
Still can't believe you guys are breaking bolts though. These are 8.8 solid steel bolts. Lighten up on the torque. ;p
I have installed several kits now but I have been using one of the smaller Craftsman rachets and open-end wrenches. Can't get much torque from these. I guess I'm just not as strong. ;p
Old May 6, 2003 | 02:15 PM
ares's Avatar
ares
Veteran
yeah in mine I stripped the thread partially, had to use a longer bolt to grab into it.
the threads its going into are aluminum, or am I thinking of the wrong place?
Old May 6, 2003 | 04:30 PM
TCL's Avatar
TCL
How thick are these bolts that everyone is breaking off? Are they really that brittle? Makes me leary about the modifcation even though the dyno in Turbo magazine shows a peak hp gain of 4.8 at 5100rpm on the Z.
Old May 6, 2003 | 06:38 PM
12SecZ's Avatar
12SecZ
I am a mere mortal of a man but these bolts they break like butter (Arnold Swartzenneger voice)
J/K my break was from unecassary over torque. Wanted it tight. After the first break you learn hehe
I only broke one. Break two that's bad lol.
Old May 6, 2003 | 07:06 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I don't think it was the bolt but instead I think I had it in a little crooked and was tightening it like that when it broke. It was only like half way in at the time.
Old May 6, 2003 | 07:10 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
It was the one in this pic. It was really hard to get to since it sits behind the hood sensor bracket. The arrows show how it sits behind this metal strip that made wrench access tough.
BTW, what does the hood sensor do......and don't say, "It senses the hood"!
Attached Thumbnails Installed My Grounding Kit Today-3a_hoodsensor_closer32.jpg
Old May 6, 2003 | 07:48 PM
fdao's Avatar
fdao
I believe that is part of the alarm system for the Z. That's the sensor to detect the act of "popping" the hood to disconnect the battery, prior to breaking into the car . Correct me if I am wrong.
Old May 7, 2003 | 02:37 AM
TCL's Avatar
TCL
So the bolts break when tightening and not loosening them. That's good to know for those who plan to do the modification.
My first thought was that Nissan put on some kind of thread locking compound that made them difficult to remove without breaking.
Old May 7, 2003 | 02:52 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
No, it was definitely when I was trying to put it back in and like I said, I think it was my fault and not the bolt. It was hard to get it in straight and I think that is what did it.
The worst part of it was that I was all by myself and I didn't have a scrub nurse to yell at and blame it on!
Old May 7, 2003 | 05:44 AM
12SecZ's Avatar
12SecZ
Yeah Bonz it's for alarm activation and warning lights on the dash if left open that's all.
I have a second one now with my aftermarket alarm.
To me that was the hardest part.
I want to also add that I have avoided painting the manifold cover part of my car because I didn't like the looks but your car it really looks nice.
Here is mine, just the bar and top panels.
http://home.attbi.com/~wegetourmail/...ID-645515.html
Think I will leave that part black. Just wanted to compliment your paint job.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
